Toytaco2 wrote:I'm no expert on this, but, I have rebuilt several old Coleman stoves now. Someone correct me if I'm wrong, but I think leaking check valves don't occur that often, if you are sure to turn the pump rod closed after you pump up the stove.
Mike
ERV wrote:Thanks guys, But I am sure it is the check valve. I can pump it up but the air comes out before I can get the rod tight. The drill looks like the way to go. Didn't find a screwdriver big enough. Was gone to Sears tomorrow. But I do have a lot of old flat spades. I will give it a try tomorrow at work. I have a wood vise there I can use to hold the tank. Thanks again for your help. I will let you know how I do.
Erv
