Glues
Glues
Postby Gage » Fri Apr 02, 2010 4:19 am
Is there a glue that will adhere (stick) to vinyl piping and wood? Like glue them together. :thinking:
Image Image Image
Gage
Images: 28
Re: Glues
Postby Classic Finn » Fri Apr 02, 2010 4:52 am
Gage wrote:Is there a glue that will adhere (stick) to vinyl piping and wood? Like glue them together. :thinking:
Dear Gage
How about trying Sikaflex 292 . There are many types of Sikaflex for different uses and holds. :thinking: :thinking: ;)
Here is the pdf info for it.
http://www.sikaindustry.com/tds-ipd-sikaflex292-us.pdf
Classic Finn
Midnight Sun Voyager
Images: 146
Postby High Desert » Fri Apr 02, 2010 10:53 am
Gage, maybe an upholstery type contact adhesive? 3M makes a good one.
I have another type out in the shop that I've used with very good results for similar apps. Will check the brand on it for you later.
Shaun
High Desert
Images: 27
Postby Juneaudave » Fri Apr 02, 2010 11:01 am
If you go the the Glue This to That Sticky and enter vinyl and wood, it recommends:
If your vinyl has a woven back we recommend:
Elmer's Carpenter's Glue
LePage's Sure Grip Carpentry Glue
Clamping can make the difference between success and failure here.
If your vinyl doesn't have a woven back we recommend:
LePage's Press-Tite Contact (solvent-based)
LePage's Press-Tite Green Contact Cement
3M Fastbond 30-NF
I don't know how any of it would work really... :thinking:
Juneaudave
Images: 380
Postby Classic Finn » Fri Apr 02, 2010 11:20 am
High Desert wrote:Gage, maybe an upholstery type contact adhesive? 3M makes a good one.
Shaun is correct on that suggestion as well. That 3M glue that Ive used is a spray on. I,ll see if I can find the can and I,ll get the exact name of it. It does work very well. :thumbsup:
Ok I found it.. here is the glue name. 3Mâ„¢ Super 77â„¢ Multipurpose Adhesive. :thumbsup: Here its expensive but works well.
Also I have the 3M 74 glue as well.
Classic Finn
Images: 146
Postby High Desert » Fri Apr 02, 2010 11:32 am
thats the 3M one I was trying to remember Hiekki. Good stuff for bonding dis-similar(sp) materials.
As Elwood Blues said- "Very sticky stuff" ;)
Shaun
High Desert
Images: 27
Postby Classic Finn » Fri Apr 02, 2010 11:34 am
High Desert wrote:thats the 3M one I was trying to remember Hiekki. Good stuff for bonding dis-similar(sp) materials.
Shaun here is the Url for other good 3M glues as well. Ive used many of them and no complaints on it.
Dont get it on your clothing or hands though. Tough to get off..Reckon Ive experienced that too. :lol:
Gage & Shaun and whoever else may be interested ;) here is the website..
http://tinyurl.com/yh4e7xs
Classic Finn
Images: 146
Postby Classic Finn » Fri Apr 02, 2010 11:37 am
Hmm wonder what Gage the Craftsman is working on. :D ;) :thumbsup:
Classic Finn
Images: 146
Postby Gage » Fri Apr 02, 2010 4:40 pm
Thank you for the responses. The reason for this question is my interior cabinet face is only 1/4" thick and I'm wanting to attach 1/8" vinyl piping common to the walls to give it that finished look. I did a test piece with staples but boy is that tricky. I use 3M-90, but for the application, spray glue is out. And with the vinyl piping being oil based, I just couldn't think of a glue that would do the job I was after. :thinking:
Image Image Image
Gage
Images: 28
glue
Postby spud233 » Sun Apr 04, 2010 5:47 pm
power grab by loctite.comes in different strengths and is in a tube for caulk gun use.depending on type used will glue all from pipe.wood, styrofoam board,metal,etc,etc.got mine at Lowes for 4bucks a tube.used this on my td build.....great holding power :applause: :thumbsup:
spud233
Images: 14
Postby dh » Wed Apr 07, 2010 5:25 pm
what about a two part epoxy?
dh
