FrankT wrote:Where do you purchase the galley struts? One of ours broke when someone pushed down on the galley lid to close it without disengaging the stuts first. Any ideas would be appreciated. Thanks!
SteveA wrote:But the way that the 120# struts were trying to pull up the hinge on the body side
wannabefree wrote:I feel your pain. I went through 3 sets of struts before I got it right. Here's what I learned by doing it wrong -
Get longer struts. Mine are almost 30 inches extended. This lets you move the struts farther from the hinge to get the same height on the hatch. That allows you to use weaker struts. That means less stress on the hinge and the hatch. People who are complaining about hinges pulling loose are using struts that are too short and exert too much force on the hinge.
The other thing I learned - most posts are from people like me. Guys who built 1 or 2, found something that worked, and expect it to work for everybody. Well, sometimes it does, sometimes not. If your gut tells you to do something different, follow your gut. Then it's your fault; not mine
