keeping things in place
Postby dh » Tue Apr 13, 2010 9:44 pm
TENNJIM wrote:
doug hodder wrote:I've got Coleman white gas stoves and drill the foot bumps on it and through bolt it with a wing nut...makes it removeable. You'd want to make sure that there is an air gap under your stove. Doug
I did the same thing with a Coleman propane stove. Mounted it to a slide-out from my galley.
8)
Jim B / Utah
How do you keep the sliders locked out to prevent a lit stove from rolling under the counter top?
dh
Postby TENNJIM » Wed Apr 14, 2010 2:25 pm
The Slideout Latch holds the shelf in when traveling. Open the latch, slide the shelf out, slide the latch-pin into place behind the shelf to keep it from sliding back in. Works great.
8)
Jim B / Utah
TENNJIM
Palladium Donating Member
Images: 35
Postby planovet » Wed Apr 14, 2010 3:14 pm
dh wrote:How do you keep the sliders locked out to prevent a lit stove from rolling under the counter top?
My stove has a lid that must be open for you to use it. That prevents the slider from sliding back under the counter top.
On another note, these are the cabinet latches that I used to keep my doors shut. There are two screws that you can tighten or loosen to vary how hard you have to pull to open the cabinet. I keep them pretty tight and they don't come open even on bumpy roads. They are a bit of a pain to align just right but they will hold tight.
ImageMark (& Cindi)
planovet
The Cat Man
Postby tk » Wed Apr 14, 2010 4:17 pm
Re: WHY? and toddler latches. The kind I'm refering to open about two inches so you can reach in to unhook the latch. Small items could fall out with the door that far open.
Best,
Escape to Missouri
tk
Postby bobhenry » Thu Apr 15, 2010 2:58 am
tk wrote:Re: WHY? and toddler latches. The kind I'm refering to open about two inches so you can reach in to unhook the latch. Small items could fall out with the door that far open.
Best,
Oh that ! we don't sweat the small stuff ! :lol:
Seriously the little items that are easily lost in my cabinets are in a 4 draw steralite unit I have mounted solid in the cabinet .
So no loose small stuff to sweat .......
I don't have a picture of it but here is a similar type of unit just a bit bigger in the galley we added for cooking and eating utensils and such.
I have added these to both trailers in the storage cabinets and the galleys they are just too handy not to.
Postby bobhenry » Thu Apr 15, 2010 3:18 am
On the topic of microwaves. We took our small one (ONCE) and it is the type with the glass plate inside.
To avoid breaking it we stuffed one of our pillows inside for transport mode. Just an F.Y.I. 8)
Postby b.bodemer » Thu Apr 15, 2010 7:26 am
Velcro and non slip mats work great.
I like the idea of packing tight in some areas if possible.
Barb
b.bodemer
Images: 328
Postby doug hodder » Fri Apr 16, 2010 10:46 pm
For me...I use rubber door stops. I just wedge them in place. The advantage to it is that it shims everything so that I get no slop in the sliders and holds everything rigid. In my case however, it's not just a stove that slides, but a whole pantry type thing that slides out. I stick one under the inside bottom and the outside edge. Sliding in hasn't ever been a problem...sliding out while towing and hitting the hatch has. I use a vertical dead bolt type thing with the bolt dropping about 3/8" into the floor to take care of that. A fully loaded cooler will run like 80+ pounds...these take care of that. Like mentioned...the rubber shelf matting is also a great idea...I use that as well in the cabinets. Doug
Postby Aaron Coffee » Sat Apr 17, 2010 9:05 am
For the drawers, I drilled holes thru the rails and into the drawers and just insert a short piece of electrical wire to hold them shut.
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
