all the feature of Kreg screws are common but not all on the same screw.. you can substitute other screws for official Kreg screws and they will work just not as easy as Kreg..H-Balm wrote:May sound silly, but I can handle that...
-do you need special screws for this?
(I saw that in the store, next to the product they had Kreg screws. Just a racket, or are they designed differently?)
-What plugs are often used? Do you use preformed plugs, as biscuits are sold in big jars? Or is a wood putty better? Or nothing! I guess that would work too.
ya, the pocket hole itself is 3/8" diameter .. way too big for wood putty. it will just shrink and fall out. wood plugs are best, next best is the plastic caps
