Please help
EDIT
I was thinking about going trick on this, and putting in a power retracting antenna, but wiring that and trying to keep is sealed would be more work than it would be worth.
dh wrote:I have a flat pannel TV antenna I like, and have no problem tucking this away in a super secrete spot
Shadow Catcher wrote:Ours has a rubber flexible antenna that works well the length is wound inside. Considering the other stuff in the tear having some one go after the radio is minor.
Engineer Guy wrote:This ex-Ham Radio geek will echo what Gus sez.
Life is a series of compromises, as I like to say. And, so it is with antennas.
One 'magical' number in the Auto world is to supply an antenna 31" long. This length is 'tuned' to the middle of the FM Radio band. It also provides a fair amount of 'metal' to receive AM station frequencies. A cardinal rule in the Radio world is that it takes 'metal' to send or receive signal. So, a connection to a TV antenna might work, but not optimally.
I own a bunch of multi-wave Receivers. One neat trick of Sony's is to have a lil reel-out antenna that clips onto the tiny Receiver. It provides the necessary 'metal' to receive shortwave signals at night.
You could run a 'stub' connection to your TD exterior, and then clip on and 'deploy' such a home-made antenna too. I'm guessing my reel-out antenna is ~20' long, and I've used it worldwide with several Cassette-sized Receivers. The [insulated] wire size is #30 or so, and it all fits onto a disc that's ~3" in diameter. Think about thin, insulated wire on a Fly Fishing Reel, and you're spot on.
Only the center, 'hot' antenna lead connection matters. The outer coaxial cable braid, that is signal 'ground', is not important. So, get a connection to the outside of the TD frame, and connect a 'reel-out' antenna to just the center lead. You'll hear immediate signal improvement, especially at night.
