That's up to you. But if you glue it good, it shouldn't mater. Oh, by the way, where did you get your Baltic Birch?dh wrote:One more question, the wall frames are made out of single pieces of 4x10x3/4 ply with the framework cut out, and will be skinned with the 5x5 Baltic Birch both sides.
Do I need to alternate grain patters when I lay them up? As in, frame grain runs front to back, so skin grain should run top to bottom?
Gage wrote:That's up to you. But if you glue it good, it shouldn't mater. Oh, by the way, where did you get your Baltic Birch?dh wrote:One more question, the wall frames are made out of single pieces of 4x10x3/4 ply with the framework cut out, and will be skinned with the 5x5 Baltic Birch both sides.
Have you talked to them about the problem. It may be something that they are not aware of. Just a thought. One time I had gotten some bad 1/8" birch from my supplier and he wasn't aware of the problem until I pointed it out. his distributor had slipped in some bad sheets. Needless to say, he doesn't use that distributor any more.dh wrote:Gage wrote:That's up to you. But if you glue it good, it shouldn't mater. Oh, by the way, where did you get your Baltic Birch?dh wrote:One more question, the wall frames are made out of single pieces of 4x10x3/4 ply with the framework cut out, and will be skinned with the 5x5 Baltic Birch both sides.
I got the B.B. at Colco Fine Woods in Memphis, TN. I have never had any problems with getting anything of questionable quality from them.
Miriam C. wrote:Do you mean that the the plywood is uneven in thickness or do you mean it has rolls in it?
