afreegreek wrote:.......axle and wheel bearings.......look like the cheapest crap they could manufacture.. personally I wouldn't touch one with a 10 foot pole but that's me. I'll buy 2 dollar T-shirts but I'll pass on the 2 dollar wheel bearings.
eamarquardt wrote:But in my experience, getting out of a hole (as in breaking down in the middle of nowhere and not being able to get replacement parts)
is a lot harder than staying out of the hole in the first place (using good quality, standardized components).
Endo wrote:eamarquardt wrote:But in my experience, getting out of a hole (as in breaking down in the middle of nowhere and not being able to get replacement parts)
Agreed, but it is easy to avoid the hole if you take the spare parts with you.
I can't count how many times I have seen a trailer on the side of the road with the tire and hub removed, as the owner is off somewhere searching for parts.
I have owned many trailers over the years (many different manufacturers).
I always carry a spare set of bearings/race/seal and dust cap.
It doesn't matter what trailer I happen to be towing a spare set is always part of my trailer tool kit.
To me it is no different than a spare tire.........I don't leave home without them.
Cheap insurance in my opinion.
Nobody wrote:........folks that 'go prepared' usually don't need the spares 'cause they've already done proper, timely maintenance anyway & won't need 'em except for unusual 'catastrophic' occurrences.
Arne wrote:bearings and seals can be purchased from any bearing supply place. Bearings and spark plugs are pretty much std world wide.
in my 50k of towing h/f trailers (2).. have never had a bearing failure.. but do carry spare parts, hammer, wooden block, etc.
If I remember correctly, the bearing no. is stamped on the bearing face. It is a std. size and easy to find.. the seal should be taken in as it is, as many are, in millimeters.. and I can not recall the width. The od/id are std, but they come in different widths..
I think about $20 covered a bearing set with seal.
I always check hubs for overheating a couple of times a day when traveling.. never had a hot one.
