Well guess its about time I posted an update. I've got a lot of little stuff done over the past few days. I'm happy to say I'm down to pretty much just some trim here and there. I've even got a start on that. Here is a few pictures of the progress.
Picture of the closet now with the paneling up. Notice I cut a slot in the lower panel and installed a piece of Clear acrylic so I can see the water level in the holding tank. Not really as fancy as one of those high dollar monitor panels and sensors but gets the job done lol Besides I already had the Acrylic. BTW that metal door is a wall safe. Its not that heavy. Its pretty much just a lock box. I needed something to be easy to remove so I could access the plumbing behind the wall but at the same time I wanted to use as much space above the holding tank.. So I robbed this out of the house haha. Its made pretty much flush so you can hide it with a picture. Don't worry I ordered another wall safe to replace it with. Even though the picture hides the hole
I just use it to keep my night stand gun out of the kids reach..
I Removed the bed frame and took the plywood off to paint it. Here is a couple of the trailer with the bed out and the bed by itself
I mounted the D rings flush with tile
Picture of my Homemade sink. Got the idea from jwhite.. Its a SS metal pan I already had with some scrap wood and FRP. Add a 20.00 faucet and a 3 dollar drain. Tada you have small SS sink
Here is a picture of the bathroom with a couple of coolers infront of the toilet to give you an idea of size.
Picture with the ceiling trim up
