angib wrote:That's an excellent plan and should be highly accurate. The only limitation is whether the teardrop is below the weight that the scale reads accurately - and I bet the tongue weight on its own is - but then a truck scale outside its calibrated range is still likely to be more accurate than a bathroom scale. So I reckon you've got the most accurate way there is.
The one thing to watch out for is that the tongue jack is probably some way back from the coupler, so the weight on the jack won't be exactly the weight on the coupler. But if your 6-wide is like the ones on Little Guy's web site, the difference will be very small - less than 10 pounds.
Remember to wind the jack so that the trailer is riding like it is when hitched up (level or whatever) to get the right tongue weight reading.
gregp136 wrote:Yup, as soon as my teardrop was finished I towed it down to the local truck stop. After about 3 minutes on the scales, the voice comes over the loadspeaker.."what the heck do you have out there?" The scales is just showing crazy numbers. We detremined that the weight of the tear was below the calabration of the truck scale.
Greg(and Laurie)
Karl wrote:Putting it back down a couple inches would clearly make sense since I'm trying to be as accurate as possible.
