Rose Rolls - The unathorized Compass Rose autobiography
Postby Sparksalot » Sun May 09, 2010 5:09 pm
Test fit.
Control side view. I'm getting cold already.
Epoxy setting on the hinge spacers. This project has been fun, because I had everything on had. I've also used up a lot of left over material. The hinge spacers required 5 inches of 2 X 1/2 oak. I had 5 inches left. Perfect.
Sparksalot
Images: 687
Postby Sparksalot » Sun May 09, 2010 5:13 pm
Will that big gangly thing be there going down the road? Nope, I still have to finish the blank to plug the opening for travel.
I was incorrect about having "everything" on hand. I need to order some T molding and weather stripping. Grant, I'll be in touch soon.
Sparksalot
Images: 687
Postby Sparksalot » Sun May 09, 2010 5:21 pm
Where does that water heater box come into this story?
Well, about a week ago, last Monday to be exact, to old WH burst and partially flooded the garage floor. Fortunately Door #2 was sitting upon a couple of blocks and did not get wet. Thing was a very good thing since I haven't applied the CPES yet.
Most of the scraps still left from the build were on the floor and got wet. More kindling for the Fall campfires.
Sparksalot
Images: 687
Postby aggie79 » Sun May 09, 2010 9:00 pm
Nice job Sparks on the door and A/C install!
And thanks for showing hinge spacers. Doors are up next on my to do list and I need to decide which method I'm going to use - t-molding on the exterior or interior jamb with seals.
BTW - I was glad to see that all of the Aggie gear was safely stored in your TD above the flood.
Postby Sparksalot » Mon May 10, 2010 9:39 pm
It was a terrible job, but somebody had to do it. 8)
Sparksalot
Images: 687
Postby 2bits » Tue May 11, 2010 1:50 am
aggie79 wrote:Nice job Sparks on the door and A/C install!
Nice AC door conversion build! If McMaster hadn't jerked me around I would have a spare set for you Tom!
Not that I am recommending it, but I used T molding and can see daylight from the inside, but never had a single drip. I have no idea why, but I am planning on the inner jamb on top of the T molding just for looks and I might as well put a seal on it so maybe both would be in order?
Thomas
2bits
2bit Member
Postby grizz » Wed May 12, 2010 4:02 pm
Makes me smile this build, we do make things hard for ourselves in making things easy.
Greetings from England.
Rian.
grizz
Images: 29
Postby Sparksalot » Fri May 14, 2010 10:32 pm
I've been considering adding an inner seal as well. I haven't really needed it however. Th PrincessHelper and I stayed dry in the rain and snow at Beavers Bend last year.
Sparksalot
Images: 687
Postby Sparksalot » Fri May 14, 2010 10:33 pm
grizz wrote:Makes me smile this build, we do make things hard for ourselves in making things easy.
I'm glad you"re enjoying it.
Nice tow vehicle you have.
Sparksalot
Images: 687
Postby Sparksalot » Sat May 15, 2010 9:02 pm
I dismantled the dead water heater. Lot's of good sheet metal in the outer jacket! Besides, "construction debris" is verbotten in the trash/recycle stream. Scrap metal for recycle is good.
The offending spot.
AND THEN:
In a flash of inspiration, or was that insanity, I had a vision of a new smoker.
Episode 4 - A New Project
Sparksalot
Images: 687
Postby Sparksalot » Fri Sep 17, 2010 9:17 pm
A little update on Door Number 2
Nearly sorta finished. Well enough to travel anyway.
With "traveling window" installed.
The good inspector was kind enough to visit last weekend.
'Ol Rose has been in the hangar way too long.
Sparksalot
Images: 687
Postby aggie79 » Sun Sep 19, 2010 9:38 am
Sparks,
Nice job on the door and AC combo! How's that smoker coming along?
:shock: So you have some of those spider web/ sawdust creations too? I've never seen these before I started my build.
Postby del » Sun Sep 19, 2010 12:23 pm
Kelly and oddball were there?
Spiders move faster than teardrop time.
Image[/quote]
Looks good though, just make the spiders rebuild or move on. :lol:
del
del
5000 Club
5000 Club
Images: 410
Postby Sparksalot » Sun Sep 19, 2010 12:51 pm
Tom,
The weather has been too hot, er um, glowbull warming has hit, to work much in the garage this summer.
I still have the idea brewing.
BTW, I hope you bring your tear to Joe Pool next week. I'm really curious to see your hatch trim. I might want to redo mine.
Sparksalot
Images: 687
Postby Sparksalot » Sun Sep 19, 2010 12:54 pm
Del,
"The Inspector" = Kilroy. There are two places in the galley where "Kilroy Was Here" indicates he visited during construction. I felt he needed a visual presence as well.
Sparksalot
Images: 687
