I created an electrical problem in Tearhead's Lil Traveler. I had a right to do it, because I'm her husband. Anyway, the 12 volt didn't work, even with a fully charged battery.
But the 120volt worked fine, powered everything. The main problem in tracking the problem was getting at the converter. It's in the galley, behind the door with the teardrop silhouette. The door isn't hinged, doesn't unscrew. Just pull straight back, and off it comes.
Inside the converter box is a 20 amp fuse under a label that says it protects the battery. That fuse is there to protect the system from morons like me, ones who put the white wire on the battery's positive terminal, and the black one on the negative. It goes the other way. If you do it wrong, the 20 amp fuse commits suicide to save the rest of the system.
So I replaced that yellow fuse, and everything works fine now. And I painted a white spot on the battery case by the negative terminal to remind myself which way the wires go.
Mr. Tearhead
