My Simple Benroy
My Simple Benroy
Postby johnthom81 » Mon May 10, 2010 10:55 am
I started this build at the end of March 2010 with the hopes of being able to have a useable, but maybe not finished, 5x10 Benroy by Memorial Weekend. My build is being done without a garage, so on weather days the work gets done inside our living room (wife is skeptical, but going along with it). The trailer was a 5x7 Yamaha motorcycle trailer that I had stretched to 10'.The outer walls are 3/4 birch plywood, cabinets are 1/2" arroco plywood. the countertop was bought premade from a big box lumber store. As of May 9, it looks like we may not have to sleep in a tent for Memorial weekend, but still have a long way to go.
I'll be right back, you be left front.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 10:59 am
I drew up this profile using Adobe Illustrator and of course made modifications as needed throughout the build.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:02 am
Tried to lay out the plywood so there would be a minimum of waste and still have some extra in case of mistakes. It has worked out very well so far.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:04 am
Here she is, folks. This will be my Benroy (I hope).
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:06 am
Grind, sand, prime. Ready for wood.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:09 am
Good karma: recycle some windows from a "Hippie Preacher" bus. $25 each, and one of them is an emergency exit window.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:11 am
The windows after cleanup.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:14 am
Here is the wall profile after stretching the plywood to 10'. Thanks so much for the tip on how to do this. And yes, that is my living room.
johnthom81
Images: 31
Postby starleen2 » Mon May 10, 2010 11:19 am
Looks good so far - I hope you aren't building it in your living room? Could prove difficult getting it out the front door! :D
starleen2
5th Teardrop Club
Postby johnthom81 » Mon May 10, 2010 11:19 am
Test-fitted the walls and found that my trailer sagged 3/4" in the middle. Great! Now what do I do? I ran a string from front to back along the trailer, measured the sag at each cross bar, then installed a shim between the trailer frame and subfloor. Came out perfect. You never know what challenges a build will throw at you, huh?
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:21 am
Built my galley lower cabinet (in the living room) and installed 3 drawers that I traded for at the Habitat for Humanity ReStore.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:26 am
Test fitted the galley lower cabinet and bulkhead. Looks pretty ok.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:30 am
Polyurethaned the walls and finished the bulkhead/galley structure installation. I'll add an 8" deep shelf with a 2" front at the top of the galley to complete this part of the structure.
johnthom81
Images: 31
Postby johnthom81 » Mon May 10, 2010 11:35 am
Here is the interior with the storage cabinet installed. Amazing how solid the structure becomes when you secure the inner structure to the outer walls. I have enough 3/4" Birch plywood left to make the cabinet doors to match the walls.
johnthom81
Images: 31
Postby grizz » Mon May 10, 2010 4:09 pm
Not just a quick build, but a very neat one too.
I like your wife, my Nicola would tollerate most of that too, I think, anyway, she once goaded me into putting a motorbike in the kitchen.
Your galley looks lovely too.
Keep us updated.
Greetings from England.
Rian.
grizz
Images: 29
