Stinky plywood.
Postby hugh » Tue May 11, 2010 8:31 am
From reading the EPA info heat will bring the odor out of the wood, if I read it correctly it causes the formaldehyde to gas off, maybe putting a small electric heater inside along with cracking a window open will ease the problem.
hugh
Images: 11
Postby regis101 » Tue May 11, 2010 10:14 am
Funny about the heat thing. I did put the Mr Buddy heater in there for a bit, thinking along those lines. I'll do it again. Couldn't hurt.
Sorry about my layman terminology. Formahl, moth ball, chemical, hospital, yucky sucky . It's all the same crap to me.
I usually end up doing (Good) things twice. The first is for the learning curve.
The second time is for keeps.
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby regis101 » Tue May 11, 2010 12:06 pm
The heat is on. The inside it totally open since it's a cargo hauler. Propped the rear hatch an inch or so for air draw. Side door cracked just a tad.
New 1# bottle. Gonna let'er cook. 9k BTU, IIRC.
Water hose is on and close. I put a smoke detector cantilevered from the roof. I'll keep checking every quarter hour or until i smell smoke.
All is well.
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby Rolly » Tue Aug 10, 2010 10:52 pm
If you really really need to seal something use Kilz original primer sealer. It will seal pet urine oder in carpet tack strip.
Rolly
Rolly
Postby kennyrayandersen » Wed Aug 11, 2010 10:04 am
every time I tell my wife this thing or that thing smells funny she is more suspicious of me than the misc. thing I'm referring to -- guess I got her trained... :oops: :oops:
kennyrayandersen
Images: 38
