wood?
Postby Larry C » Sun May 16, 2010 7:26 am
afreegreek wrote:
doug hodder wrote:Veneers used, glues, moisture content and a whole lot of money.....
At the risk of catching a lot of flak, I'll go out on a limb and say that for a tear, marine grade isn't necessary and I'd be willing to bet that very few do use it. I've used it as a overlay on top of my exterior grade ply sides, just because I wanted the mahogany. Living in Dayton, your humidity isn't so high that it is required for a build. Precautions should be taken to seal all the edges, whether it's marine grade or otherwise. I've used it on 4 of my tears for the sub floor and the walls, but used MDO on the last tear. Medium Density Overlay....takes on an epoxy coat great if you are doing a painted tear.
There are plenty of tears built from exterior grade that are doing just fine. I had a '49 Kit that I'm sure wasn't built from marine grade or exterior grade for all I know, and was in great shape after 40 years. It too was in a drier climate. Doug
marine grade ply is not necessary but for the few extra dollar you get a lot more than just waterproof adhesive. real marine grade is tested and certified. it has high grade core veneers and face veneers as thick as the core veneers. it's a much higher quality product all the way around whereas exterior grade is generally a lower quality product with a better glue.. the other factor is it's finish quality, hit it with 220 and your ready to go.. both faces too.
all things considered it's the best bang for the buck there is.. you get all the attributes of baltic birch with a real waterproof glue. can be had in many species, some that are half the weight of baltic birch and it comes in 4x8 and 4x10. you can also get it with the grain running across the panel if you want it.
I agree, Marine plywood is really the best choice. I have used it for kayak building with no issues. My problem is finding it. I am in Central NYS and it is impossible to find anyone that sells Okume plywood. I did find Baltic Birch, but I was told by the supplier that Baltic Birch is definately not exterior and will delaminate if exposed to any moisture. He showed me a piece of 1/8" that was damaged and discarded in their dumpster. It had rained a couple of times on it. It was warped and severely delaminated.
I still bought 4 sheets anyway, to use on the interior. I intend to seal everything with epoxy inside and out, with glass on the exterior. I am still looking for Okume ply within 150 mi.
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby doug hodder » Sun May 16, 2010 9:17 am
That's all well and good, and I agree, probably the best choice.....but they can be built without it. Marine grade ply isn't always available all over the country.
Postby angib » Sun May 16, 2010 10:43 am
As it stands in Britain:
- marine and exterior use exactly the same glue;
- marine will have better, thicker face veneers than exterior (and more, thinner core veneers on thick plywood);
- marine won't have the internal repairs and voids that exterior is allowed to have.
It's the last of these that makes marine so valuable for boats - when continuously immersed, an internal void will attract moisture, even through an epoxy surface.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby teardrop_focus » Sun May 16, 2010 1:23 pm
^ ^ ^ Nice to see you, Andrew.
afreegreek
^ THIS.
I most definately am willing to pay a little more for these particular grades of plywood. And, since I am building a 9-footer, I'm also looking for (four, three to build with and one to doubley cover a possible mistake, then use for spars and bulkheads) 4 X 10.
Please! Could you provide any known sources or other industry names to possibly aid my local and regional search for "some that are [nearly] half the weight of bb and it comes in 4 X 10"?
I would appreciate any help in this area IMMENSELY.
teardrop_focus
Images: 127
Postby H@nk » Sun May 16, 2010 4:33 pm
I bought 3 sheets 18 mm or 3/4, 5'x 10's for walls and floor.
For the inner seeling I bought 5 scheets 3 mm or 1/8 baltic birch.
The outside seeling is made of hardboard with epoxy with glass sheets.
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
Postby Classic Finn » Sun May 16, 2010 5:00 pm
angib wrote:As it stands in Britain:
Andrew
As it stands in Finland: I couldnt agree with Andrew on this more. He is right on with his information. :thumbsup: :thumbsup:
This holds very true here in the Land of Finnish Plywood.
Also for info: Ive used Marine Grade Finnish Ply on our tear. And the tear has been basically outside for many years already and nothing has gone bad on it so far. Have to make sure that the cut ends are sealed properly also.
Here in Finland the weather changes rapidly. Short Summers, Wet Fall, Long cold winters. And the Ply I used is still as new.
Classic Finn
Midnight Sun Voyager
Images: 146
Postby afreegreek » Sun May 16, 2010 8:32 pm
teardrop_focus wrote:^ ^ ^ Nice to see you, Andrew.
afreegreek
^ THIS.
I'll ask the person who does the ordering at work tomorrow for the name and number of our supplier.. I know it's a US company.. as the wrapper is plastered with US flags.
afreegreek
Postby teardrop_focus » Sun May 16, 2010 11:50 pm
afreegreek
I'll ask the person who does the ordering at work tomorrow for the name and number of our supplier.. I know it's a US company...
Image Image Image
[omg]Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you... Thank you, thank you, thank you...[/omg]
:awesome:
teardrop_focus
Images: 127
Postby afreegreek » Thu May 20, 2010 8:17 pm
afreegreek
Image Image Image
:awesome:
OK, didn't take me as long to find our sources name as it did to find the thread again...lol
anyway, here's our supplier.. you might contact them to get a local supplier who carries the same products..
http://www.westwindhardwood.com/price_marine_ply.php
afreegreek
Postby dh » Thu May 20, 2010 8:28 pm
Out of my price range.
dh
Postby Rock » Fri May 21, 2010 5:15 am
Wow - I consider myself fortunate for finding my Sapele plywood for $20/sheet!
Eric
Rock
Images: 48
Postby Blackjack » Fri May 21, 2010 10:23 pm
WOW, not that is pretty plywood!
Blackjack
Postby KenC » Sat May 22, 2010 7:38 pm
afreegreek
^ THIS.
Here is a link to Frost Lumber, a local San Diego. Take a look, this is where I plan to purchase my wood for my 5 X 10 Benroy
http://www.frosthardwood.com/
KenC
Images: 41
Postby KenC » Sat May 22, 2010 7:39 pm
afreegreek
^ THIS.
Hi Chris
Best Regards,
Ken
KenC
Images: 41
Postby teardrop_focus » Sun May 23, 2010 11:23 am
Thank you! very much, 'greek and Ken...
Pondering the product choices for a few days
:thinking:
teardrop_focus
Images: 127
Users browsing this forum: Google [Bot] and 11 guests
