Grid Runner Adventures wrote:ya but you have to build wheel wells in if you build it off frame still ? do you just build it and cut them out after the fact ?
That's what I did. First I built the wheel wells.
Then I built the wall around the wheel well. This is the inside of the wall.
Then cut the opening to fit the wheel.
keep the cut out as a form so you can bend trim around it.
