Haven't seen any new frames posted in a while
Postby dh » Tue May 18, 2010 11:57 pm
Well, looks like things are moving pretty slow here, and I haven't seen any new frames posted in a while, so lets see some custom frames, new or old.
Here is a pic of mine
dh
Postby Ageless » Wed May 19, 2010 12:02 am
So why are the bracing for the tongue located at different locations? Where they join to the 2nd crossember?
Ageless
Postby eatatjoz » Wed May 19, 2010 12:10 am
Looks like a perception thing.
If I was to guess, it's a 3x3 frame flipped upside down and the camera angle just makes it look offset.
Just a guess though.
edit: and the dog didn't like being in the garage, got bored and tore the insulation out of the bottom section of the door.
eatatjoz
Postby dh » Wed May 19, 2010 5:33 am
Yep, it's upside down, just a trick of the camera. I'm mobil tonight but I'll put up a different angled pic tomorow night when I'm at work.
dh
Postby dh » Wed May 19, 2010 7:06 pm
Well, I guess this is the only other pic I have that even remotely shows the tongue members. Still can't really tell though. I guess you will just have to trust me that they are evenly spaced on the 2nd Xmember.
Image[/img]
dh
Postby WesGrimes » Wed May 19, 2010 7:40 pm
Its not new, but here you go: :D
WesGrimes
Images: 31
Postby teardrop_focus » Fri May 21, 2010 2:20 am
Ageless
That's to keep the weight down to the inside for roundy-round racin'. :D
*spits*
Now right here's yer road-racin' chassis:
:dancing
Those two pics are so fresh that I haven't even started a build thread yet...
:lol:
teardrop_focus
Images: 127
Postby dh » Fri May 21, 2010 4:13 am
Are you using the torsion half axles on those plates? Good looking frame :thumbsup:
dh
Postby WesGrimes » Fri May 21, 2010 7:35 am
teardrop_focus wrote:Image
:dancing
:lol:
That is a great looking frame design!
WesGrimes
Images: 31
Postby teardrop_focus » Fri May 21, 2010 11:23 am
^ Thanks, Wes! Image
dh
Sir. Yes, sir.
I might have achieved similar effect if I'd used a Dexter (full) axle... but this way (maybe) we can get the torsion axis (axle) another .5 to 1.0 inch closer to the tear cabin floor... thus reducing the necessary "up" start angle for the trailing arms (wheel spindle) yet still keep a lower center of gravity.
Now... using a leaf spring setup as Wes has done w/ a dropped axle nets the same result... and there's nothing wrong w/ leaf springs especially when small hydraulic dampers are fitted. A rubber torsion axle, either half (Flexiride) or full (Dexter - there are others too) isn't much lighter in weight, suprisingly... but the setup can be more compact and will allow independent wheel (suspension) travel for slightly better bump absorbtion for on-road use. Off road is another matter entirely and this chassis is not being built for that (although I do expect to see the occasional, "improved" unpaved road surface from time to time).
The whole thing was inspired by two sources: W.A. Harper's Quik-N-Easy teardrop's simple cross (using 2.5-inch square tubing and half axles) and the U.K./euro/Andrew/angib's Ultralight chassis which consists of a simple triangle connecting the hitch to the axle.
At first I wanted to make the simple cross, then use angle iron to form the diagonals... and punch the angle full of holes for that vintage motorsport/steampunk vibe... but clean holes are a lot of work for something that will remain mostly hidden underneath the teardrop cabin floor and cabin (sides) walls.
:thinking:
Thanks for your compliments! You're the first here on T&TTT to see this thing!
teardrop_focus
Images: 127
Postby dh » Fri May 21, 2010 7:26 pm
Just curious, what tubing are you using? What is the (estimated) frame weight?
dh
Postby dh » Fri May 21, 2010 7:28 pm
I guess if I had payed attention to the pic, I could have seen the half axle in your hand :lol:
dh
Postby WesGrimes » Fri May 21, 2010 9:06 pm
This one is not mine, but I find it very interesting:
WesGrimes
Images: 31
Postby dh » Fri May 21, 2010 11:07 pm
Interesting indeed. Talk about a light frame. I wonder what that trailer is rated for.
EDIT:
I wonder what axle that is. Dexter puts a bow in thiers.
dh
Postby WesGrimes » Fri May 21, 2010 11:21 pm
dh wrote:Interesting indeed. Talk about a light frame. I wonder what that trailer is rated for.
EDIT:
According to their website, it is a Torflex, which is Dexter. Total weight of 275lbs with a 700lb cargo weight capacity.
http://www.letsgoaero.com/ProductDetail.asp?Pid=29
WesGrimes
Images: 31
