Well I bit the bullet today and cleaned up that lantern I got. The more I tore it apart and reading in a collectors forum I am even more convinced it is a L227. I cleaned it up, didn't polish it. The font was not to bad. One thing that says this is a real L227 is that the fuel pickup tube is soldered to the top of the font and not the fuel valve so it stays in the font. Appears that is very particular to the L227. Put it all together and .....................................
I had never been in that deep in anything like this before. Cleaned the mud wasp nest out from inside the collar (it was an old one). Bent the frame straighter. The check valve was leaking back a little. I got it out without to much trouble and bunch of carb clleaner and compressed air and it now holds pressure. Got an O ring from hardware store for the fill cap, it is a different on than the one on my 220. and that cap would not thread onto this one. The generator is an original one. It was plugged up but with carb cleaner, compressed air, WD40, compressed air, carb cleaner, compressed air, repeat. It now works. The generator has no tip cleaner so have to tread lightly. I have no idea if I put the correct mantels on it. I have several sizes here.
Now it needs a proper cosmetic cleaning, new globe and frame derusted.
