by Wolffarmer » Wed May 26, 2010 9:12 pm
I been practicing lighting that beastie. Mine has the straight generator and not the coiled one. Not sure if all L227s came with a coiled one or if they changed in production, I do know that they did not come with the tip cleaner generator. I have found that I can let the pressure off the tank, give it a few pumps. crack the valve just a bit then right back off. this will let a tiny bit of gas to run down the generator. Light that up and when the flames are about out the mantles are glowing and can open the valve back up. Not to much flaming doing it this way. Without the coil generator is pretty hard to heat the generator with a match. I don't have one of those fancy gas bbq lighters. And i sure am not going to light up my Oxy/ acetylene tourch.
