![Sad :(](./images/smilies/econ_sad.gif)
Please and Thank you!
![Smile :)](./images/smilies/econ_smile.gif)
oh yeah, it has Hellsman spar and has a second coating of Minwax Clear Shield......
48Rob wrote:Miriam,
If it is peeling off itself in large sheets, perhaps the two products were not compatible after all, or, there was a problem with adhesion due to some other issue?
If all the layers are peeling off the wood, with none remaining in the damaged areas, I'd be concerned that the stain, or other finish used on the wood was not compatible with the varnish...
If that is the case, a stripper and refinish may be the best option?
Rob
Boodro wrote:Ahhhh,,, Happy sanding Auntie M!!!!![]()
If you sand it smooth & finish with a fine grit , you should be able to re varnish with no problems. Good luck.![]()
P.s. Mine did the same but I had it outside & did not see it & water got under the varnish & turned black, what a PAIN@![]()
Sanding it did no good it was into the sub layers . Thats why my TD is red now.
btw---we caulk the trim on our houses----why not our TD's?
