My Heart Goes Out To The Fine Folks Along The Gulf Coast...
Postby asianflava » Mon May 31, 2010 2:44 am
I know nothing about drilling, but on another forum I visit, there were some roughneck Coon-asses that were PO'd. Not only because of the spill, but because it happened because BP was cutting corners.
The poster on the other board said that they weren't using mud in the well, they were using seawater instead. I'm not sure exactly what that means, but someone here probably does.
asianflava
Postby Miriam C. » Mon May 31, 2010 1:43 pm
Mud is a heavy, cement like stuff they pump in to permanently seal the hole. Shouldn't be too hard to find out what they are pumping in because it is put in on the surface.
Postby Miriam C. » Mon May 31, 2010 1:53 pm
The one things that keeps coming back is that this is a deep well. New drilling in shallow water is only done by the Chinese and others that Cuba leases to. Last I heard the USA was not allowing close drilling even though the same territory was being drilled. :? :? :?
Now if you really like conspiracy theories---well I bet there will be one out soon. :lol:
Postby caseydog » Mon May 31, 2010 2:29 pm
Miriam C. wrote:The one things that keeps coming back is that this is a deep well. New drilling in shallow water is only done by the Chinese and others that Cuba leases to. Last I heard the USA was not allowing close drilling even though the same territory was being drilled. :? :? :?
There are shallow water wells all over the Gulf of Mexico, including much of the American Gulf coast. Go to the beach in Texas and you can see them dotting the seascape.
I believe that Florida does not allow them along their shores, because the tourism industry there is stronger than the oil industry.
The Western half of the Gulf is pretty heavily tapped, but the eastern Gulf has some fairly promising oil reserves that haven't been explored. Some of these are in deep water, which was too expensive to drill in when oil was cheap. Oil prices need to stay high for these reserves to be commercially viable.
Many Americans believe (with help from politicians) that the government was holding the oil industry back from exploring these reserves, but the real obstacle was cheap oil from the Middle East. Why drill if you can buy it for less from the Arabs?
BTW, what they pump into a well to cap it is concrete, which has to be mixed differently for different depths, probably due to the different temperatures. A mile down, the water can be below freezing temperature. Apparently one thing that went wrong on the BP well is the wrong mix of concrete was pumped down to the well.
Mud is the nickname for the mixture of fluids pumped down through the drill and out the drill bit to lubricate and cool the bit, and pump drilling debris up and out of the well.
CD
My build journal is HERE
caseydog
Images: 515
Postby asianflava » Mon May 31, 2010 10:13 pm
caseydog wrote:I believe that Florida does not allow them along their shores, because the tourism industry there is stronger than the oil industry.
Correct, FL does not permit drilling, a lot of good that did. :roll:
asianflava
Postby caseydog » Tue Jun 01, 2010 1:06 pm
Bill Maher interviewed Philippe Cousteau Jr., grandson of Jacques Cousteau about his recent trip to the Gulf. Here is video...
http://vodpod.com/watch/3735806-philipp ... e-any-more
caseydog
Images: 515
Postby Kayperkay » Tue Jun 01, 2010 11:26 pm
This is why we need MORE regulation. 8)
Kay
Director Jefferson State Tearjerkers
Life is Devine Chaos....Embrace it...Forgive yourself......Breathe.....And enjoy the Ride...!!
Image Image Image
Kayperkay
Images: 66
