Different method of attaching ceiling
Postby prohandyman » Sat Jun 05, 2010 3:50 am
Current build for a customer required white fiberglass shower panel as a ceiling, in a light weight camper. So with trying to eliminate any extra wall thickness and weight, we decided on 1/2" ply walls which made routing my usual rabbit for the ceiling to nest in out of the question. So I laid the panel out on horses, attached the spars to the top side with adhesive, and laid the whole panel in as 1, attaching the spars to the side walls as we moved up. Worked great!
Dan
prohandyman
Images: 785
Postby Classic Finn » Sat Jun 05, 2010 5:35 am
Excellent Dan. I like this method much. Thank You for showing this. :applause: :applause: :applause:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Juneaudave » Sat Jun 05, 2010 7:35 am
I wondered if you might be able to do it that way and have nice finished results....Thanks Dan
Juneaudave
Images: 380
Postby S. Heisley » Sat Jun 05, 2010 8:44 am
You were absolutely "thinking on your feet"! :thumbsup: ...Impressive and well done. Thanks for sharing.
Postby Arne » Sat Jun 05, 2010 8:50 am
great idea. I put the spars in first, but this is much better. how come I didn't think of it?
Now I know why I look at the notes here...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby madjack » Sat Jun 05, 2010 2:57 pm
we did that very thing on our first build except we were using bendy ply...worked doggone good :thumbsup:
madjack 8)
Postby mikeschn » Sat Jun 05, 2010 6:13 pm
You should try adding cleats like NorthernMN.
http://tnttt.com/viewto ... ats#692292
