12 Volt Outlet Wire Question
Anything electric, AC or DC
You've asking for it now!
Postby eamarquardt » Fri Jun 04, 2010 8:29 pm
You need a few lessons in electricity. Keeping it simple a battery developes a voltage potential. You want to use that potential to push electrons (flow is called current) through a wire to run a load (light bulb, motor, etc). So you connect the battery to the load with some wire. Now it gets a little more complicated. Wire has resistance and will consume part of the power you'd like to get from your battery to your real load (light bulb, motor, etc). The bigger the wire the less resistance it has and the less power you lose in your transmission wire and the more that gets to the load. The more power you lose in your wire, the hotter it gets, till, if you push too far, it will get hot and start a fire. With small currents/loads, the amount you lose in the transmission wire is small. The more current you try and push through a wire the more power you will lose as a result of the wire's resistance. Bigger wires have less resistance and will carry bigger currents, lose less power, and not get as hot as small wires. Fuses or circuit breakers should always be used to prevent too much current from flowing through a wire by blowing or tripping before the wire is damaged.
I think the book you are using is a little more conservative than necessary. House circuits use 14 gauge to carry 15 amps ( and 12 gauge for 20 amps) for a lot longer distance than any teardrop will, but there are some subtle differences between 120 volt and 12 volt power transmission.
Anyway, your wire is plenty big, as stated before you can get spade connectors that will fit your wire, and be ok. I think that the cigarette lighter type recepticles are rated for about 10 amps. I agree that the little white wire that came with your recepticle was a little whimpy but you can get away with short runs of small wires as the resistance is pretty low in a short small wire but would be too high in a long small wire. I have a number 14 or so wire that I push 300 (three hundred) amps through on a regular basis! It is, however, water cooled and if the water stops flowing, it will melt pretty fast!
Hope this helps.
Cheers,
Gus
eamarquardt
Images: 150
Wire Size 101
Postby Engineer Guy » Fri Jun 04, 2010 10:07 pm
I've dealt with this issue many times over my career, so let me try to un-muddy the waters...
My reference is always some version of the Chart linked below, and I've used 'ohms/1,000' for any given wire size. It's easy to get your head around that length and ohmage for mental math.
http://www.powerstream.com/Wire_Size.htm
Yes, 1,000' of #18 is >6 times the resistance of #10. While that's true of even short wire runs, it takes 1,000' of wire for this difference to be even a few ohms total. The short run of #18 wire likely will be inconsequential in the real world. Yes, a short bit of #18 will act as a 'fuse' relative to the #10, but only during long periods at maximum amperage [current] that #10 wire can carry, especially if the #18 run cannot air cool itself.
I used to advise folks making long, unwieldy wire/cable runs to run wires in parallel for any given size. You could do the same, and parallel another #18 or larger wire to the existing #18 wire. This trick would make the effective resistance of this short run ~half of what it was, or ~3 ohms [if it were #15 wire 1,000' long].
It's important to realize that resistance is evenly distributed along the length of any wire. That resistance difference is not all 'crunched' disproportionately into the short run you show in your very helpful pix. 'Run the numbers' to see #10 vs. #18 wire resistance in the relative lengths you're using.
The short length of wire on the connector ground side was because the expectation is that is goes to vehicle ground closely adjacent, or it grounds through mounting screws. This is not the case in a wood frame TD. It is assumed that the positive lead, +12 VDC run will be much longer, and more prone to resistance-related voltage drop, than a short ground connection made adjacent.
What you've got are called 'spade lugs' in the world of us 'sparkies'. You could buy a couple more spade lugs, and crimp on a larger size wire. It would then slip on the 'male' connector 'paddle'. Spade lugs come in various sizes, so take in what you have to match it in size [width].
I crimp and solder everything and put heat shrink tubing around it. Alternatively, connections should always be mechanically sound [crimped or twisted] before you solder. Wires should be firmly twisted together well before a wirenut is put on to withstand road vibration. Old timers put electrical tape around secured wirenuts as well.
Last, I've had Cig Lighter plugs themselves overheat and melt. Resistance is proportional to contact surface area. The rounded end of the Cig Lighter tip is WAY too small to carry the amps req'd in many applications. In what is called 'the thermal runaway effect', the tip of the connector corrodes or degrades as it heats. The resistance of it then increases. More voltage drop thus occurs across it, generating more heat, which corrodes it more. And so on... This is why Honda and other Generators use 'blade' plugs at unique angles to carry even 8 amps @ +12 VDC. Blade plugs distribute current over more surface area, overcoming resistance and thermal runaway inherent to small contact area. My point: there's other safety 'weak links' in about any Cig Lighter connection used to carry 'high' amperage vs. worry over a lil run of #18 wire.
Plug a 'high' amperage draw Accessory into your completed plug and hold the #18 wire in your hand to see if it heats up 'excessively' to you. That real world test will trump all theory. I think the same way, so I appreciate your viewpoint. There is a hypen in A-R! ;-0
~Reality proceeds with or without your consensus~
Engineer Guy
Images: 118
Postby S. Heisley » Fri Jun 04, 2010 10:21 pm
:? Confused?
I apologize if I have confused some of you. It was not my intent. I guess I should have written just the question without adding in the chuckles of last evening's wiring adventure; but I thought you would enjoy the read. (I laughed just writing it.) While I really appreciate how kind and helpful you all are to answer, I think I need to set some things straight for a few of you.
:no: It’s not about spade connectors or disconnects to use to connect a device.
While covered up a bit, if you look carefully, you will see in the pictures that I posted, I am already using spade connectors (also called 'disconnects') and, while you can't see it in my pictures, yes, I am using the correct size required for each size of wire.
:no: It’s not about what wire size to use for the circuit.
Yes, I am using a bigger wire size than many, (including the authors of some of the books and internet sites I've reviewed) think is necessary. However, as long as the wire is bigger than I need, it is not really a problem. If it were smaller, it might be a problem; but mine is not.
:QM Here is my question, singled out:
Is the little piece of wire that the manufacturer sends with their 12 Volt outlet necessary and if so, why?
:thinking: But, Don’t answer yet
I have emailed the manufacturer/distributor, Prime Products and they have replied that they will answer the question on Monday. When they do, I will post their answer here and the mystery will be solved and put to rest.
:hammerhead: Once again, I say, “Sorryâ€
Postby S. Heisley » Fri Jun 04, 2010 10:35 pm
Engineer Guy:
Wow! :shock: Thanks a bunch for your reply! What you said makes a lot of sense. :thumbsup:
Re: Wire Size 101
Postby eamarquardt » Fri Jun 04, 2010 11:49 pm
Engineer Guy wrote:I've dealt with this issue many times over my career, so let me try to un-muddy the waters................
Although "Engneer Guy" doesn't look like a "regular guy" to me, I'd listen to her as she speaks with very straight tongue and with far more detail than I wanted to get into!
Cheers,
Gus
eamarquardt
Images: 150
Postby S. Heisley » Fri Jun 04, 2010 11:56 pm
Gus, the avatar pic is of his beautiful wife and, yes, he is very knowledgeable.
Sucker punched!
Postby eamarquardt » Sat Jun 05, 2010 12:04 am
S. Heisley wrote:Gus, the avatar pic is of his beautiful wife and, yes, he is very knowledgeable.
Boy did I get "suckered in" on that one, ha!
Cheers,
Gus
eamarquardt
Images: 150
Postby S. Heisley » Sat Jun 05, 2010 12:36 am
Yup! Ya did. :applause:
Postby Engineer Guy » Sat Jun 05, 2010 8:57 am
Having been in the Manufacturing World for so long, I'll speak for std. practices while letting Prime Products send you their own answer, unaffected by this Forum, I'm sure. Besides the electrical aspect of the issue, there are others...
The Neg. connection 'pigtail' likely was there to go to one of the Cig Lighter receptacle mounting screws, and adjacent vehicle ground. On the Chart linked again below, you can also note the amps a #18 wire can carry for 'Chassis Wiring'. A relatively-small ground wire helps the Manf. cut costs if they make a bazillion of this receptacle or if they spec their receptacle for 'only' 10 amps, for example... The receptacle/connector Manf. market is unbelievably competitive, and shaving off a penny or so matters. A pigtail also allows for connection to a longer wire, as in your application, if the receptacle is mounted to a dielectric.
Having wired so many of them recently in our self-built Solar Home, reference a std. 115 VAC electrical outlet. While the mounting screws contact the earth ground internal to the receptacle, and could be grounded by mounting screws to a metal box [I used plastic], one still has to make a separate ground connection to the green screw at the bottom of the receptacle. Mounting screws loosen [especially in mobile applications] and well-made wire connections do not. While it may seem a bit like wearing a belt and suspenders, wired connections to all connectors is Code in some Industries, and simply good practice in others. Especially in the litigious world of today, a Manf. has to cover all bases via good practices while anticipating how some doofus might mis-wire a product and burn down something. Perhaps my favorite example of this 'overcompensation' are the warnings on Lawnmowers against sticking your hands underneath where a rotating blade might 'relieve' you of having 10 digits. Darwinism in practice there... A runner-up might be the warning that a cup of Coffee contains 'hot' product. One can only hope... And Viagra warnings? Let's not go there.
Hee hee, it never occurred to me that the pic of my Wife on an Oregon beach would be misconstrued as me. It surely never has happened when you see us simultaneously! She lived in a Tipi in the Rockies years ago, so she's a great sport about Camping, whether in a 5 Star Biz Hotel abroad or on our Land.
I enjoyed your writeup!
Engineer Guy
Images: 118
DC power connectors!
Postby eamarquardt » Sat Jun 05, 2010 9:59 am
Engineer Guy (not a woman after all and I'm sure he's not nearly as pretty as his wife!) brought up an excellent point that the cigarette lighter sockets have an inherant design weakness in the contact area of the little round point that all the current must flow through. Due to the limited surface area and the possibility of corrosion compounding the issue they can overheat, cause a big voltage drop, and potentially cause a fire, etc.
As far as I know there is no "standard" for 12 volt DC power connections as there are for AC voltages and currents. For example my Honda generator uses one plug and my Coleman genarator uses another.
The closest thing to a standard that I'm aware of (many Ham Radio orgainzaions are "standardizing" with them) are Power Pole connectors. They have addressed the problems with the cigarette lighter type connectors. They are not real cheap but, IHMO, are worth considering for 12 DC load panels.
http://www.powerwerx.com/anderson-powerpoles/
Cheers,
Gus (aka AB6KS)
eamarquardt
Images: 150
Postby S. Heisley » Sat Jun 05, 2010 10:03 am
:thumbsup: Thanks again, Engineer Guy! :thumbsup:
Postby S. Heisley » Sat Jun 05, 2010 10:18 am
We don't have to wait until Monday. Here is the Prime Product response:
Sat, June 5, 2010 7:07:00 AM
Re: Information Request From Your Web Site
Add to Contacts
To: S Heisley
I would agree with the information provided by electrical engineer. I also agree with comments on Cig Lighter plugs themselves.
Best regards,
Nick
Postby Shadow Catcher » Sun Jun 06, 2010 7:00 am
One of my concerns with the MM concerns the solar panels and current loss when panels are placed remotely, or on top of the house at home when not on the tear (grid tie to generate 110). The power poles were my solution. I do not trust the cig lighter type sockets for other than very light duty use.
Low Voltage ~ Solar PV Panel Connections
Postby Engineer Guy » Sun Jun 06, 2010 10:19 am
Without intending to hijack this thread, I'll post this minutae on MC4 latching connectors on PV Solar Panels as follow up to the comment above. To swap a Panel from Home to Mobile use, one would have to deal with these Industry-standard MC4 connectors:
http://store.solar-electric.com/incaforsoelp.html
http://www.google.com/search?sourceid=c ... ing+Cables
Regarding dealing with DC current and related losses, even modest-size Home install Panels are typically connected in series. This allows for smaller diameter wiring [<coaxial cable size], since one is then dealing with high voltage, not high current. Home Inverters accept up to ~600 VDC, typically. A lil Solar Industry 'secret' is that some Cloud 'fringe' effects can cause PV Panels to output higher voltage/wattage, as can reflectivity from snow or water. So, one has to de-rate total voltage output and compensate for this occasional effect. Installers I've spoken with wire Panel arrays serially to put ~400 or 480 VDC max into the Inverter as a design safeguard.
I met the fellows who founded 'Evergreen', so I'll give them a mild pitch here. They're from the Semiconductor Industry, and make their PV Panels much like Semiconductor 'wafers' [raw IC 'chips'] in terms of depositing multiple layers of Substrate material consistently for quality assurance. A fellow here asked why one Panel costs more than the other. Initial quality and sustained wattage output over time is the answer. See here one Panel at a great price/watt that would keep some serious Deep Cycle Batteries charged in a modest Roof footprint [~17 Amps/hour @ +12 VDC assumed output]:
http://www.millionsolarroofs.com/evergr ... ctors.aspx
Note that the Kyocera Panel linked below outputs 17.7 VDC max; very typical. All PV Panels I've ever seen up close output more wattage than specified due, in part, to outputting voltage than +12 VDC. Output is known to drop up to ~50% over some Panel lifetimes as the internal junctions degrade. Improved Manf. processes are changing this characteristic, however.
http://store.solar-electric.com/kyso130wa12v.html
I'm heartened to hear that Cig Lighter connectors are slowly going the way of black, rotary dial Telephones.
Engineer Guy
Images: 118
Postby Ageless » Sun Jun 06, 2010 10:47 am
I don't use the Cigar lighter plugs. For low amp usage, I install the small low-voltage plugs.
For the higher draw needs; it's either a soldered connection, or power poles. But then, I'm know for over-engineering.[/img]
Ageless
Return to Electrical Secrets
