dh wrote:Make a template out of scraps, then use a template bit, which has a bearing on the top, and cut those openings out, as the bearing will ride on your template, life should be relatively easy.
kennyrayandersen wrote:dh wrote:Make a template out of scraps, then use a template bit, which has a bearing on the top, and cut those openings out, as the bearing will ride on your template, life should be relatively easy.
Yes, I second that.
The router manufacturer should also (unless you got a REAL cheap router) sell some accessory guides as well that screw into the bottom center of your router base. The guide is cylindrical, but has a hole that goes through the center axis. The router bit goes through this hole in the guide. The guide rides up against your hole template, which has to be just slightly larger than the hole you want to account for the difference between the guide and the router bit diameters. This way you can make one template and then use it over and over.
The bits with the guide bearings also work very well – just depends on what you are trying to do.
