Windows in doors/ i messed up!!!
Postby Wolffarmer » Sat Jun 12, 2010 5:20 pm
Forrest747 wrote:this is fun to figure out.
We do seem to have a strange sense of what is fun.
Also as a carpenter told me years ago "The mark of a true craftsman is how well they hide their mistakes" That was the day I found out about electrical outlet mistake plates. saved my bacon.
Randy
Wolffarmer
Images: 309
Re: Windows in doors/ i messed up!!!
Postby afreegreek » Sun Jun 13, 2010 8:44 pm
Forrest747 wrote:Ok I admit it i messed up. in cutting out the holes for my windows in my door. the jigsaw blade went at an angle and made the opening at the back way to big. I should of listened to wife who said use the router. ( She was one smart cookie) anyhow the damage has been done. I am also in a pickle that even if i hadnt messed the cut how to attach these windows to the door.
So was thinking of just scraping the idea all together i have other windows in Charley and just fixing the doors, ie cutting it out square and patching the hole closed. i hope i am making sense. Pictures to follow later. :?
your wife is a smart cookie.. a router is by far the best solution.. but clean straight cuts around corners with a jigsaw are possible.. the best blades I've used so far are Bosch "progressor" in the taper ground series..
afreegreek
Postby Forrest747 » Mon Jun 14, 2010 1:23 am
Oh she was the best for sure. Anyhow what I did was order some flexiable molding that is used in home construction. Thinking it will do the trick.
Forrest747
Cowbell Donating Member
Images: 447
