interesting and unanticipated hatch leak!
Postby Cliffmeister2000 » Mon Jun 14, 2010 12:25 pm
Well, folks, I thought I had done a bang-up job on my hatch, used a better than hurricane hinge, sealed it well, etc. Sure enough, it doesn't leak.
At least, until I open the hatch. Then water runs down the open hatch to the hinge from the backside, which I had not anticipated and did not seal! Guess the hatch is coming off and some butyl rubber going on!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby bobhenry » Mon Jun 14, 2010 12:37 pm
Here is an option cliffy and it works ......
Postby Miriam C. » Mon Jun 14, 2010 12:39 pm
:( Cliff you might give some consideration to putting a rain diverter on the hatch so when up the rain goes off to one side. A slight lean will send it where you want it. 8)
Postby bobhenry » Mon Jun 14, 2010 1:05 pm
Carol had trouble with her factory tab
We even converted Rian in Jolly ol' england
I was fortunate I multi layered mine during the build and have not had the 1st drop of water intrusion up or down !
Here is an old thread that might help !
http://www.tnttt.com/viewtopic.php?t=36852&postdays=0&postorder=asc&start=0
Postby madjack » Mon Jun 14, 2010 1:35 pm
Cliff, if you did not seal, yes you need to do so...be aware, when open and under certain circumstances, the HH can leak thru the barrel.................
madjack 8)
Postby Miriam C. » Mon Jun 14, 2010 1:43 pm
:shock: :lol: Not me. I read too much and mine is :worship: fine so far.
Re: interesting and unanticipated hatch leak!
Postby planovet » Mon Jun 14, 2010 2:38 pm
Cliffmeister2000 wrote:At least, until I open the hatch. Then water runs down the open hatch to the hinge from the backside, which I had not anticipated and did not seal!
That is a problem with that particular hinge. Like Miriam said, a diverter will help a lot. I plan on putting one on mine. In the meantime, my entire hatch stays under the 10x10 and I make sure if rain drips off the 10x10 then it drips off onto the roof and not the hatch.
ImageMark (& Cindi)
planovet
The Cat Man
Postby mcspin50 » Wed Jun 16, 2010 5:16 pm
At International Northwoods Gathering 3 held a couple weekends ago here in lovely Minnesota, Craig from Camp-Inn was pointing out to me how they secure a piece of waterproof fabric from under the roof side of the hurricane hinge to under the galley side of the hinge leaving enough slack in the fabric so that the galley can open up fully. The fabric runs from one side to the other and acts like a drip pan catching any rain that might get between the two parts of the hinge. Do my words make sense or would it help if I draw and scan a picture? :?
Would this solve your problem Cliff?
Lil M.
In every walk with nature, one receives far more than he seeks. - John Muir
Generic Benroy Build Journal here - My LilScamper Update Journal here
The Lily Pad...Image My LilScamper...Image Image
mcspin50
Images: 158
Postby Cliffmeister2000 » Wed Jun 16, 2010 6:16 pm
mcspin50 wrote:At International Northwoods Gathering 3 held a couple weekends ago here in lovely Minnesota, Craig from Camp-Inn was pointing out to me how they secure a piece of waterproof fabric from under the roof side of the hurricane hinge to under the galley side of the hinge leaving enough slack in the fabric so that the galley can open up fully. The fabric runs from one side to the other and acts like a drip pan catching any rain that might get between the two parts of the hinge. Do my words make sense or would it help if I draw and scan a picture? :?
It sounds like it would, but I'm not 100% sure I'm following you... :oops:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby mcspin50 » Wed Jun 16, 2010 10:44 pm
I'm thinking it would be something like this. Since I haven't become personally acquainted with a hurricane hinge, I'm not entirely sure if this is exactly what I saw,but I think it's close. Hope this helps make your repair less traumatic.
Lil M.
mcspin50
Images: 158
Postby Juneaudave » Wed Jun 16, 2010 10:47 pm
mcspin50 wrote:I'm thinking it would be something like this. Since I haven't become personally acquainted with a hurricane hinge, I'm not entirely sure if this is exactly what I saw,but I think it's close. Hope this helps make your repair less traumatic.
Great detail!!! :thumbsup:
Juneaudave
Images: 380
Postby Cliffmeister2000 » Wed Jun 16, 2010 10:49 pm
Thanks, I'll give that some thought... :thinking:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Von Pook » Wed Jun 16, 2010 10:50 pm
I also used an old bicycle tire over our hinge, it works perfect.
Eric, the camping sound guy
Von Pook
Images: 10
Postby rainjer » Wed Jun 16, 2010 11:22 pm
Cliff, I had a similar problem last time I went camping. It was coming thru the hinge. (mine has butyl tape and is caulked) I added a piece of 1/2" aluminum angle over the hinge flange. I bought a 6' length for $6 at Ace hardware.
I put it even with the edge of the hinge and over hung it 3/4" past the end. The hatch opens without any problems. I sprayed a hose on the hatch with it open and 99% of the water run off the sides.
Jeremy
rainjer
King Koleman
Images: 11
Postby ssrjim » Wed Jun 16, 2010 11:32 pm
Cliffmeister2000 wrote:Well, folks, I thought I had done a bang-up job on my hatch, used a better than hurricane hinge, sealed it well, etc. Sure enough, it doesn't leak.
I dry the door before I open it :)
93079
ssrjim
Users browsing this forum: Bing [Bot] and 6 guests
