Planning on using 3/4 inch finish sided ply.
Trailer frame will be 4X9
Box will be 5X9
Do I need to frame the floor so protect the 6 inches sticking out each side if I plan to bolt the 3/4 to the frame to every cross member front to back? Meaning Front, 2nd, 3rd, 4th, 5th, and rear cross member.
If no frame under the plywood, I would weld in short supports to extend out under the door on both sides to provide for someone sitting there.
Question is can 3/4 finished plywood handle a load extended out 6 inches without a frame under it?
Guy
