zapj wrote:I have read posts on different methods such as lap joints and scarf joints for plywood. Has anyone considered or tried this method? On the two edges to be joined first install a 1x glued and screwed to the edge of each sheet. Step two would be to put glue on the facing 1x's and the end grain of the plywood. Step three would clamp the 1x's together thus pulling the edges of the plywood together and secure with screws. This method would seem to add your backing under the plywood joint and also apply pressure fo a glued butt joint. Just looking for input for a wacky idea.
