Sly1990 "Cmd Post" UPD 07-19-10 - 120V Electricity
Postby sly1990 » Mon Jun 14, 2010 9:59 pm
Are these two different thoughts? Or are you thinking about trying to run an AC unit through an inverter?
No, That was the idea.... :lol:
I didnt took a final decision yet about the AC.
The TD is heavyly insulated.... (I Think) :lol:
...and the Cabin has about 35 sq/ft. (130 cu/ft)
The AC I saw is 600W (~50-55A continious 12v) total power at Maximum
setting (Combined Fan+Compressor). It's also rated for 150 sq/ft.... (1200 cu/ft Assuming a 8' ceiling)
IMO, Running it only 3-4 minutes when needed cant be worse than a Minn Kota Fishing/MotorGuide Motor. (I guess... correct me if im wrong) :oops:
Does anyone runs a 120V AC over his(her) Inverter successfully??
What battery type, how many of them, which kind of inv etc have you?...
If going the 6,000BTU AC way, my bigger issue would be more about the localisation...
There's no way I could install one on the rear of the trailer. (Even if small)
The only possibility would be thru the cabinet on front... (but I only have 10" depth available) :thinking: :cry:
I wont cut on Sleeping Area.... And dont want a ugly cut square on front of TD.
I think I'm pretty screwed anyway with the positionning...
Back to the project :
My Configuration under counter top should be :
On the left:
3 Drawer (15"½ wide facade)
In the Middle (15" Wide)
Lower compartment: Battery (or Bank, Battery switch, Charging Relay.
Upper compartment: Fuse Block, Ground Bus, 120V Source Relay (Inv/Ext), 25A Intelligent Charger, Fuse ANL 250A.
On the Right: 26" Wide
1800W Inverter on top upside down (Fixed under Countertop)
26" wide, Cooler Tray. (Or Future Fridge)
sly1990
Postby sly1990 » Mon Jun 14, 2010 10:00 pm
Finaly the 3rd page!!! :applause: :lol: :thumbsup:
sly1990
Postby sly1990 » Sat Jun 19, 2010 11:23 pm
DAY 10
Today I bought :
1x Hole Saw Kit 55$ (60% rebate... value 135$)
1x 120V Inlet 27$
6x Sleeve for Contura Switch. (4 End + 2 center) 13$
1x Countertop 22"x60" 75$
1x Laminated Pine 11/16"x20"x48" 33
Total : 203$
Grand Total Yet : 1677$
The 120V 15A External Power inlet...
The Contura switch sleeves I bought.... looks cleaner and it hide my wood chip mistake.... :D :applause:
The Tool I borrowed at work... pretty usefull for my switched and 120 outlet holes.
Starting the Countertop...
It was too long and to wide... I used a saw table to reduce it to 56½"x19½
Re-glued the whole thing and added screw like crazy.... It wont move... :lol:
sly1990
I realized that the rear of the cabin has enlaged at the extreme end of it.....
Its 56"5/8 (It should be 56"1/2). I realized that when installing the counter top...
After some adjustement it looks good now... ;)
Starting the Electric Cabinet
Using some spare Laminated Pine for the shelf separating the battery compartment and Electric panels, switch, fusebox, AC charger etc...
The 2"x3" in the middle of the picture is to keep the form at 56½" while finishing the rear cabinets &
While cutting the AC Outlet hole, I realized that I was ending right in the Interior cabinet shelf...
Fortunatly, I had the Fein Tool to cut easely a piece of it by the outside.. :worship:
Everything temporary in place just to take a look (Including the Quarter Circle)
Still need sanding and more coating of Varnish.
sly1990
Postby sly1990 » Sun Jun 20, 2010 10:46 pm
Today I bought :
1x 1"x6"x8' Pine (for Front of Drawer) 11$
1x 1"x4"x10' Pine Drawer Sides 10$
1x Varnish Varathane 1000 (In aerosol. For finishing...) 12$
3x 1"x2"x10' Pine (Side of Cooler Tray + Cabinet Framing). 20$
1x 1"x4"x6' Pine (floor etremity finish) 9$
1x 18" Heavy duty Drawer Railing 22$
Total : 84$
Grand Total Yet : 1761$
Pics coming soon...
Didnt brought the camera with me today :x
sly1990
Postby sly1990 » Sun Jun 27, 2010 11:04 pm
DAY12
Today I Bought
Varnish Spray 12$
3x 16" Heavy duty Drawer Railing 60$
1x Box of 1" Floor Screw 20$
2x Quarter Circle 10" PJT 7$
3x Wall Skirting PJT 10' 15$
1x Metal molding 9$
1x pair of hinges 6$
Total : 126$
Grand Total Yet : 1887$
Doing some Framing (I'll describe the electric cabinet config later)
The Drawers Unvarnished (Still need some adjustements)
The hinges... I use the same inside for the Cabinets.
Quality Drawer Rail.
sly1990
Since Inverter or Charger will produce heat (but never at the same time) both will be set in the same compartment.
I'm thinking about having a second small vent in the counter top too.
Also, the 120V Source Automatic Relay will be place behind the intelligent Charger.
Varnishing the Front of Drawer and the Electric Cabinet.
The 1800W Heavy Duty Inverter. (Picture Upside Down. It's fixed under countertop)
This thing is 20,1" x 10,8" x 4,0" :shock:
Blue Sea BatteryLink Automatic Charging Relay (60A)
Blue Sea ATO Fuse Block 120A
Blue Sea Ground Bus
1/0 AWG Wire. (4 feet red + 3 feet Black)
25A Intelligent Charger (For Charging when connected on External 120V power source)
250A ANL Fuse and Holder (On the Left)
300A Continous Battery Selector (1, 2, 1+2, OFF)
.[POS 1] = Batt
.[POS 2] = Unused for now
.[POS 1+2] = To Inverter and Power distribution Block
**Battery shown is for visual purpose only. This is an old group 24 staring battery. I'm waiting for a Group 31 Deep Cycle DC31-280.
sly1990
Postby PhotoGuy » Mon Jun 28, 2010 9:37 pm
really looking good. :thumbsup:
PhotoGuy
Postby sly1990 » Sat Jul 03, 2010 10:52 pm
Thanks :thumbsup:
DAY 13
Today I Bought :
3x 11/16"x12x96 pine40$
2x 1"x2"x8 Pine 9$
Total : 49$
Grand Total Yet : 1936$
Thursday I vanished the whole thing under the counter top.
Today, I Just finished the 12V side of Electric Compartment.
1/0 AWG Wire for Inverter (Red+Blk)
8 AWG Red For Bue Sea Fuse Block
8 AWG Black For Ground Bus
8 AWG Black For Inverter Chassis Ground
AC Charger Cable
ACR BatteryLink Cable (10AWG)
**All Wires are Marine Grade.
I used the Radio ignition wire on one of the Switch of the panel. :thumbsup:
TV 120V Outlet.
sly1990
Postby sly1990 » Sat Jul 03, 2010 11:42 pm
View from inside of the left interior cabinet...
The 12V & 120V Rear Counter outlets. Also, a 120V interior outlet for the TV.
Almost finished the Roof Insulation.
Temporary Speaker for Test Purpose... :lol:
sly1990
Postby PhotoGuy » Sun Jul 04, 2010 12:01 am
great work. Nice detail. I have gotten a lot of ideas from watching your build.
Keep up the good work :applause: :thumbsup:
PhotoGuy
Postby grizz » Sun Jul 04, 2010 2:36 am
Great progress.
You guys do put a lot stuff in there. :thumbsup:
Greetings from England.
Rian.
grizz
Images: 29
Postby Ratkity » Sun Jul 04, 2010 8:50 am
I've loved watching your build! Your attention to detail is mind boggling to me (as well as all the other people who do builds!).
Hugs,
Ratkity
Ratkity
Postby Miriam C. » Sun Jul 04, 2010 9:17 am
:thumbsup: :applause: :thumbsup: Very nice, all the way through! Keep up the good work!
Postby sly1990 » Mon Jul 05, 2010 12:13 am
Thanks all.... :) :R :thumbsup:
Everything while building is a challenge to me....
*Except the Electricity that was a piece of cake. :D
The question that keeps coming is :
OMG, how the @#$% should I do That.... :oops:
sly1990
