dh wrote:
As to the reverse polarity fuses, wouldn't they also protect the battery from receiving a reversed charge current? Self resetting breakers have a place but imho in the event of a short I would rather have a fuse blow and stay dead than have a breaker cool down then give juice back to the circuit. Imagine bouncing down the road and having a wire rub its insulation off. Hit a bump, trip the breaker. Breaker resets untill you hit the next bump and short again.
That makes sense. I think I'd install a battery disconnect that would protect you in the above scenario. The battery could be activated once parked at the campground. One should have a battery disconnect anyway as it prevents battery drain.
Digimark:
Although it is always good to be protected, I would call the WFCO service line and ask them if you need that in-line fuse. The write-up on your converter reads as if everything is already protected.
Do add and use a battery disconnect, if you don't already have one.
Unless the campground electrical has a problem, if the converter/battery fuse is going to blow, it will probably happen when you first hook up the battery. Still, it doesn't hurt to carry an extra fuse for that campground possibility. They're small and don't take up a lot of room. So far, around here, I've only found 30 Amp ATO/ATC fuses and they only come one to a package (not expensive). I'm still looking for a source for 40 Amp fuses. If you're out camping when it blows, you could have problems finding the fuse you need.
