Hatch trim clearance
Postby aggie79 » Mon Jun 28, 2010 5:41 pm
On my teardrop, I'm using RV roof edge molding along the roof/sidewall junction and on the hatch. Along the roof edge, I've installed it "tight" to the sidewall. How much horizontal clearance should I allow between the inside vertical portion of the RV roof edge molding and the galley sidewall of the teardrop?
(I was thinking to allow about an 1/8" clearance.)
Thanks for your responses.
Postby chorizon » Mon Jun 28, 2010 7:01 pm
I just ran into this problemo myself. I ended up with between 1/8 and 1/4 on mine.
We went on a little shake-down cruise recently and even went through a decent "West Texas" thunderstorm and everything stayed nice and dry!
I was...surprised...!
...and very happy! :thumbsup:
chorizon
Images: 94
Postby aggie79 » Tue Jun 29, 2010 8:19 am
Thanks Joshua. You confirmed my hunch.
Postby Chuckles2153 » Wed Jun 30, 2010 3:12 pm
aggie79 wrote:Thanks Joshua. You confirmed my hunch.
Would either of you guys post some pics of your trim please.
I'm getting real close to that step and would feel a little more comfortable doing it if i saw what other people have on theres.
Thanks in advance, Chuck
Chuckles2153
Images: 74
Postby aggie79 » Wed Jun 30, 2010 5:15 pm
Chuckles2153 wrote:Would either of you guys post some pics of your trim please.
Chuck,
I'm using the "wide-lip" RV Roof Edge molding from Grant at Li'l Bear. I don't have a real good picture, but this shows how it looks installed (without the vinyl strip that will cover the screws.)
Postby chorizon » Wed Jun 30, 2010 6:52 pm
The left side was the first to get the trim and it turned out quite nice...
The right side was more of a PITA. I had to relocate my holes. This piece will be replaced soon. I am embarassed to show this, but I hope it helps someone else out there... :thumbsup:
I used 1 X 1 X 1/8 6063 Architectural Aluminum that I pre-drilled, then annealed.
chorizon
Images: 94
