steveaus wrote:I've got a white cargo trailer that gets quite hot inside in the desert sun. I realized the roof is bare, unpainted aluminum.
Any suggestions on what I should use to paint it white? Just plain-old white paint?
I would look for one of the insulating elastometric coating designed for mobile homes.....
Any idea why the factory leaves the roof unpainted?
errrr, because they can and it's cheaper that way................
michiganflipper wrote:here is what i used on my trailer and it seem to make a big differnt http://www.koolseal.com/
Jeffmo63 wrote:I am going to try Rustolem Marine White. It is relatvely inexpensive and I got it right off the shelf at Menards. See my album for pic of 140 degree roof temp. Also, per the recommendation of several I am installing a Fantastic vent. A little pricey but I am assured they are worth the money. Good luck.
steveaus wrote:Jeffmo63 wrote:I am going to try Rustolem Marine White. It is relatvely inexpensive and I got it right off the shelf at Menards. See my album for pic of 140 degree roof temp. Also, per the recommendation of several I am installing a Fantastic vent. A little pricey but I am assured they are worth the money. Good luck.
That's an impressive photo! Have you taken a measurement in comparable conditions with the Rustoleum Marine White?
kennyrayandersen wrote:I’m just curious, but it seems like I remember that aluminum might need some special prep work, no? Do keep us posted on the process, and the results (long and short term).
Jeffmo63 wrote:Yes, I think you are right about the aluminum. But I am nearly certain my trailer top is sheet steel like the sides. I had planned on washing it down really well with soap and water, rinsed, and followed with a scuffing with one of those green weenies (3M Scotchbrite pad). A wipe with mineral spirits just before painting ought to do it.
