razorback wrote:I was lucky enough to find a salvage yard that bought out a shower stall enclosure company's inventory. It was white FRP that was 6'8" wide.
I did the exterior walls, roof and the interior walls and floor. I bought all this for 108.00 dollars.
On the exterior surfaces I painted with Krylon fusion paint which is designed for plastic surfaces. Over the Fusion paint I then used a latex exterior house paint from sherman williams. The paint guy says the house paint will adhere nicely to the krylon fusion paint. coated in 07 and still holding up well.
Larry
Do you cover the screws? What do you use to trim the edges?
