What works well for counter top?
Weight
Postby eamarquardt » Sun Jul 04, 2010 12:13 pm
Not to hijack the thread:
Although my build is probably on the heavier side (frame and no lack of wood structure) it's not a major concern for me as I can't ride in small vehicles due to the nature of the ride so will always tow with a crossover or or mini van.
I have seen the interiors of some big motorhomes and am in awe of the lack of concern about weight. My experience towing my utility/dump trailer is about a 15% drop in mileage when towing it on the highway (it weighs a ton empty). I expect the teardrop to be better due to the areodynamics.
Everything is a compromise but the big boys sure don't seem to be concerned with weight. I wonder if they have tested and determined that weight doesn't play that big a part after you get past a certain point?
I think there are a lot of reasons to keep the weight of a teardrop within the limits of the tow vehicle. I kinda think a granite countertop is over my line, ha. A few tile proably won't contribute that much (particularly if you leave out the wonderboard).
Cheers,
Gus
eamarquardt
Images: 150
Postby caseydog » Sun Jul 04, 2010 1:46 pm
deceiver wrote:
chorizon wrote:
caseydog wrote:
d30gaijin wrote:
planovet wrote:2x2 stone tiles :D
Very nice looking but doesn't that add a fair amount of weight? :thinking:
There's a guy in the Houston area that used a solid slab of granite for his galley top. Honest, I've seen it -- so has PlanoVet.
Hey cat, do you have pictures of BigDE's granite galley?
CD
Cat no repondez?
I dug this up from last year's Guadalupe Adventure...
That may not be granite. You see what looks like that on a lot of bathroom vanities. I had one myself. It's made from milk bottles.
Nope, it really is granite. That is the first question everyone asks when they see it, "IS THAT GRANITE??!!!" :o
Yep, it's granite. :lol:
My build journal is HERE
caseydog
Images: 515
Postby Crazylegs » Sun Jul 04, 2010 3:35 pm
Thanks yall I found some formica that I can use half for counter and other half for a table that will hang on the outside. I am strugeling with how to do my cabnets any sugestins?
Crazylegs
Images: 72
Postby Juneaudave » Sun Jul 04, 2010 3:50 pm
Be sure to check out the Galley Gallery for ideas!!!!
Juneaudave
Images: 380
Postby planovet » Mon Jul 05, 2010 8:20 am
caseydog wrote:Nope, it really is granite. That is the first question everyone asks when they see it, "IS THAT GRANITE??!!!" :o
Yep, I've seen it and it really is granite. Very impressive! :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby RvMan56 » Sat Jul 24, 2010 7:15 pm
I am gonna paint ours bright yellow and add several coats of polyurethane.
:twisted:
RvMan56
Postby rebapuck » Sun Jul 25, 2010 4:02 pm
In my VW, I have just a small counter. I used a standard 18x24 wood cuttingboard. I wasn't thinking when I installed the first one. Put screws on 4 sides and it buckled from expansion/contraction. Second one was installed with just two hinges along one side.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby bobhenry » Sun Jul 25, 2010 4:10 pm
I made the flip out cabinets with 1/2" osb and covered it with a halo of luan veneer around an insert of 4" tile. I layed the tile out in a manner where nothing had to be cut and framed the area with the luan halo. I used brite white rubberized bathroom caulk to set the tile in and to grout it with. About 4000 miles and all are where I put them. Has worked out better than I planned and hot pans and propane cooktops are no worry at all.
Postby GPW » Sun Jul 25, 2010 4:22 pm
Thinking a nice sheet metal top over 1/2" plywood would be practical , LIGHT, burn proof and you could bend up the rear edge as a splash guard ... Copper would be attractive/decorative , and not too expensive ...
Postby Prem » Tue Jul 27, 2010 1:16 am
I got Formica remnants from Habitat for Humanity's RESTORE for $5 a piece, then glued them down to 1/2 inch plywood. :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby chukar » Wed Sep 08, 2010 9:39 am
I used a scrap of floor lino on a 3/4" ply top. Think I paid about $10 at a carpet store. Easy to cut and install; used lino floor glue. I like the rubberized surface for its no-slide aspect and it is easy to clean. I still have plenty left to redo if ever needed or for another project.
[img]http://www.tnttt.com/gallery/image.php?image_id=62803[img][/img][/img]
chukar
Images: 32
Postby csgmtu » Wed Sep 08, 2010 8:37 pm
I used a heavy higher quality stick on tile. Not the cheapos, the ones that are made to look like slate. got em at Menards :)
csgmtu
Palladium Donating Member
Images: 6
Postby Sam I am » Wed Sep 08, 2010 9:09 pm
I used laminated pine shelving. It's stiff, but not real heavy. It's finished with 3 coats of glossy urethane varnish. Is has worked well for 4 years. It resists water and grease very well.
Sam I am
Images: 106
Postby vtx1029 » Wed Sep 08, 2010 11:58 pm
vtx1029
Images: 70
Postby chukar » Thu Sep 09, 2010 9:43 am
vtx1029 wrote:How about a HDPE cutting board?
Order the size you want here
http://www.interstateplastics.com/Natl-Hdpe-Cutting-Board-Sheet-HDPNEC.php?sku=HDPNEC&vid=201009082356-1p&thickness=0.375&dim2=24&dim3=48&qty=1&2=Price+it+%3E%A0%A0
Surly you jest.
$54 plus $45 shipping for a Cargo Trailer cutting board?
Here is one from Wally world like the one I have in my Cargo (got mine for $2 at a garage sale) for under $12 with tax.
Oh, now I see what you are talking about. Using it instead of ply and formica....actually not a bad idea for a teardrop size.
http://www.walmart.com/ip/Mainstays-12X ... d/13397991
chukar
Images: 32
Users browsing this forum: Google [Bot] and 10 guests
