don't try this one! AND new teardrop about to be christened
Postby bfitz » Fri Jul 09, 2010 9:08 am
So I started my build in a garage in October...bought some cold weather hardener for my RAKA epoxy, but didn't get to the point of really needing it until it was 95 degrees out. Rather than making yet another trip to buy stuff, I figure I'd give the cold hardener a shot...failure!!! Pout life about 4-5 minutes...the cup was too hot to hold!!!
As for the build...it's getting really close. Tomorrow, filon skin/roof, windows and door. The next day, trim it out, lights, etc. Then....I think I can camp!!!
bfitz
Images: 22
Postby Miriam C. » Fri Jul 09, 2010 10:10 am
Well I guess you know the stuff is still good..... 8) :thumbsup: Your TD looks great :thumbsup:
Postby Ageless » Fri Jul 09, 2010 11:52 am
Put the resin and hardener in the fridge; once cold, it will take longer to kick off
Ageless
You did not burn down the house
Postby glassice » Fri Jul 09, 2010 3:27 pm
So this makes you a full pledged Fiberglass person looking great
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby NathanL » Fri Jul 09, 2010 6:49 pm
Use a baking sheet will increase the "pot" time of epoxy as well. Here when it gets to 105 and I'm boat building even using the slow hardener requires cooling it and putting it in a flat style pan to reduce the heat.
Put it in a baking sheet and put the baking sheet on something metal to pull the heat out of it while you work.
NathanL
Postby kirkman » Sat Jul 10, 2010 6:59 am
It's looking good! :thumbsup:
kirkman
Images: 55
