Building in Montana
Building in Montana
Postby wingnut » Sat Jul 10, 2010 11:09 pm
Hi All,
I've been lurking on here for a few months and have been building for a couple. But just got a photo program so I can post some pics of my build. Now all I have to do is figure out how to post pictures on a forum, which will be a first for me.
wingnut
Images: 46
Re: Building in Montana
Postby michaelwpayton » Sun Jul 11, 2010 5:34 am
wingnut wrote:Hi All,
Hey wingnut... check this out http://www.mikenchell.com/pichelp.html
-Michael
"all things should be as simple as possible... but no simpler"
michaelwpayton
Postby wingnut » Sun Jul 11, 2010 9:37 am
This is a picture of the old boat trailer that I modified for the TD.Image
wingnut
Images: 46
Postby teardrop_focus » Sun Jul 11, 2010 11:24 am
Welcome to T&TTT.
What part of Montana? It's a big place. :R Other teardroppers in your area would like to know.
I grabbed two pics from your album; hope you don't mind!
Great-looking trailer frame...
From the Album of wingnut
How long's that floor? You don't necessarily say so, but I'm assuming you're building a teardrop rather than a 4-wide tiny travel trailer.
Nice job so far!
teardrop_focus
Images: 127
Postby wingnut » Sun Jul 11, 2010 12:10 pm
I'm in northwest Montana, in Kalispell, that's about 32 miles west of Glacier National Park.
The TD deck is 10 foot long & 4 wide. I'm using a set of Kuffle Creek plans as the bases for my build with only minor mods. The frame is 4"X1.5"X3/16" channel iron, so it's heavier than the 2x2 box tube specs in the plans. The axle is also pretty heavy duty. I removed springs to hopefully soften the ride some and of course I had to narrow it up more than a foot.
wingnut
Images: 46
Postby teardrop_focus » Sun Jul 11, 2010 12:20 pm
Flathead Lake is huge. I've got some distant relatives in Whitefish and have worked in the area near the Issac Walton Lodge at the southern end of Glacier. Beautiful country!
Let us know if you ever need even milder-rate leaf springs. I don't have the link handy, but I do know of a supplier for load ratings down to 500 lbs! No sense in having one's rig want to change lanes when hitting bumps.
:lol: :thumbsup:
Again, welcome to the board! I'll be keeping an eye on your build.
:campfire:
teardrop_focus
Images: 127
Postby wingnut » Sun Jul 11, 2010 12:35 pm
Focus,
I was thinking that I might have to go to lighter rate springs, but I thought I'd try just removing a couple of leafs first and see how it rides, then make other changes as needed.
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 12:41 pm
I sealed the underside of the deck before fitting 1.5"urethane insulation to it, which will be fastened after the wiring and any other work needs to be done under the trailer.
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 12:42 pm
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 12:47 pm
ImageHere I was fitting the side to the deck to make sure it was OK before cutting out the other side.
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 12:50 pm
It looked good, so here is the second side fitted to the deck and the boss came and checked it out also. She's not ready to give it the GOOD TEARDROP KEEPING SEAL OF APPROVAL just yet.
wingnut
Images: 46
Postby Miriam C. » Sun Jul 11, 2010 12:52 pm
:thumbsup: :applause: You have a wonderful start to a great teardrop!
Postby wingnut » Sun Jul 11, 2010 1:04 pm
Thanks Aunti M,
I'm git'n it done.
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 1:23 pm
In this pic the wiring is all done & the walls are insulated.
Then the interior walls are sheeted and the cross members installed.
and the lid is on.
wingnut
Images: 46
Postby wingnut » Sun Jul 11, 2010 1:28 pm
This bring use up to date. Yesterday I stained the interior and finished the insulation of the roof, so that is where I'm at to date with my TD build.Image
wingnut
Images: 46
