Wheel Rim Size
Wheel Rim Size
Postby Baz » Wed Jul 21, 2010 5:49 pm
I am building my frame and an ready to order my axle. The question I have is I found a good deal on some rims, 15x6 with 5 on 4.5 bolt pattern. Are these ok?
Baz
Postby azmotoman » Thu Aug 05, 2010 9:53 am
Those are Mopar and/or Ford Ranger rims. While 15" keeps the bearings cooler (fewer revolutions), tires may be a bit pricier if you stick to the ST rated trailer tires. I bought 2 tires for our woody (205/75/14) yesterday for $69/M&B $10 apiece in Mesa at a local trailer supply, mom-n-pop type shop. If you can find similar pricing for a true trailer rated tire in that 15x4.5, then go for it. Be careful to allow for spring sag and fender height as you continue.
Money isn't everything, but it keeps the kids in touch!
Dinero isn' ¡t todo, pero él mantiene el interés de los niños!
azmotoman
Images: 10
Postby emiller » Thu Aug 05, 2010 9:57 am
That is a good choice of rim size.
emiller
Images: 157
Postby aggie79 » Thu Aug 05, 2010 10:22 am
I don't want to over-complicate this, but you may want to think about:
1. Checking the backspacing of the wheel to be sure it clears the torsion arm (if you are using a torsion axle) and to see how it would affect clearance between the sidewall (if your wheels are outboard of the sidewalls.)
2. The wheel has a large enough opening to clear the axle hub.
This is speaking from experience. The (reasonably priced) wheels I initially wanted to use would not fit over the axle hub and, if they had, they would not clear the sidewalls.
Postby azmotoman » Thu Aug 05, 2010 10:32 am
This might also help in you planning:
azmotoman
Images: 10
Postby dh » Fri Aug 06, 2010 7:04 pm
This post looks really familiar :thinking:
Didn't we just do this a few weeks back?
If I remember Baz, the whole backspace and torsion arm clearance issue was discussed.
EDIT
Oh, I see the OP was back on July 21, looks like it got bumped or something. Here is the original thread:
http://tnttt.com/viewtopic.php?t=38835
Must have been a double thread or something.
dh
Postby Larry C » Sat Aug 07, 2010 7:34 am
I'm also about to buy my axle and wheels. I will be using a Dexter 8 torsion axle. What I am not sure about is how do I know if the wheel will clear the axle arm without trying them?
Do I look for a wheel offset that keeps the axle arm outside of the rim edge?
What about brakes, do they require a different wheel? Also, how to determine tire width for body clearance?
Is there a tutorial that helps one determine axle, wheels, and tires when all that is known is frame width?
This is Andrew's drawing from another post:
Image :?
Larry C
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby teardrop_focus » Sat Aug 07, 2010 5:07 pm
The wheel diameter measurement arrows in this pic may be misleading... but only slightly.
Careful w/ the rim dia measurement if choosing tires based on what one might pull from a junkyard.
The wheel dia (and tire dia) should be measured from where the tire's sidewall bead sits IN the the wheel rim lip - not the outermost lip-to-lip of the wheel bead.
teardrop_focus
Images: 127
Postby teardrop_focus » Sun Aug 08, 2010 11:32 am
Larry C
The diagram here in Larry C's post is more accurate in regards to wheel/tire diameter...
Most torsion axle trailing arms have a 4-5 inch center-to-center distance... add the thickness of the material on either side of these centers and you wind up with approx 6.5-7 inches. You'll have no problems w/ a 16 in wheel. I see 15" and 14" wheels fitted to torsion axles all the time, but did not study the backspace/trailing arm relationships... People like Grant Whipp of Lil Bear, or Gabe at So Cal Teardrops or madjack; people who have fitted wheels to several Dexter installations would know.
Converting later to the commonly-available Dexter Axle electric brakes' backing plates and brake drum/hubs is usually not an issue because "coaster" hubs are manufactured w/ the same hub face placement as the electric brake drum's hubface.
You'd need to know body width also... then apply the info posted above.
I planned my first-time effort using 2" as the distance between the tire and trailer body. I had to plan the axle's hub-to-hub distance after I determined body width and wheel offset.
teardrop_focus
Images: 127
Postby Alphacarina » Mon Aug 09, 2010 6:21 pm
The backspacing issue is easy to solve with a pair of billet aluminum wheel spacers - They bolt to the trailer axle with the studs you usually bolt your wheel on with and they have a new set of studs for you to mount your tires. $50 to $75 on eBay. I'm using 15 by 6 automobile wheels with a 5 by 4.5 bolt pattern (Mazda) which match my FWD car so I needed a spacer. The 1 1/2 inch spacer effectively turns my 40mm offset wheels into zero offset wheels, so the bearings in the hubs are centered in the wheel . . . . like they ought to be. I've towed 1300 or 1400 pounds 11,000 miles in the past 3 years using these spacers. You can buy the spacers in 1 inch, 1.5 inches and 2 inches to suit your needs
For a lightweight trailer with 13, 14 or 15 inch wheels, you don't really need ST rated trailer tires - You can safely use any automotive tire and run it at 28 to 30 psi just like you do on your car. I replace the tires on my car when they still have a bit of tread left and since I have 8 identical wheels for my car, the new tires go on the other set of 4 wheels and the old car tires become my trailer tires - Effectively giving me free (and matching) trailer tires. Another 'plus' is that the same spare which works on your car also works on your trailer . . . . and if you should have *2* flats at the same time, you can take the wheels/tires off the trailer so you can drive to town and get the flats fixed . . . . while the wife stays behind to guard the trailer ;)
Don
Alphacarina
