lindstrand wrote:I am just about ready to build my door and I am concerned about warping. I was thinking making it with 2x2 spruce and 1/8" plywood like I made my walls. I have a fairly large door 28x30 so I think overtime it will warp and cause sealing issues. I am trying to think of the best and cheapest way to make a door. Couple thoughts I have is run tensioned cables corner to corner but this interferes with my window. Fiberglass over the plywood pricey and I don't know how much resistance to bending that would add. Use aluminum instead of wood for studs and thats pricey and I can't weld aluminum. Laminate plywood together for a solid door but that would be heavy.
Anyway enough thinking out loud any comments or experiances (good or bad) would help
Juneaudave wrote:I'm not to sure that I've heard any tales of woe related to warping of composite doors (other than those being glued up with a warp built in). Seems to me...a door with 2x2 framing and 1/8 ply sheeting shouldn't be susceptable to warping if the wood is dry and the door sealed....
timlsalem wrote:I agree with everyone else that said "if the door is made out of dry treated wood and is sealed right there won't be any warping" If you can't get by your fear of your door warping I suggest you make it out of aluminum. Even if you choose to build from wood, and it does warp, what's the big deal of building another door?
timlsalem wrote:I just looked into your album and can't see any pictures of what your doors will be made from. Could you post some of the sides your planning to cut the doors from?
Corwin C wrote:I'm contemplating the same issues for my build for the same reasons. My proposed solution (I haven't actually built it yet) is to maintain the torsion box structure by adding a layer of 1/8" ply under the strips. It will either make the wall thicker or reduce the insulation, however, like Larry C stated, once the strips are done, there's no going back, so maintaining a rigid structure during the building process is paramount.
My current wall lamination design (subject to change) will have:prefinished wood flooring for the interior (5/16" thick)
Proposed construction process will be to lay up laminations (except for exterior strips and fiberglass) and vacuum bag to a flat floor. At this point the torsion box should be secure and the door can be cut out. Temporarily re-attach the door from the inside, then the stripping can be applied to the exterior. Cut and trim strips to match framing and apply fiberglass, wrapping edges of door and door opening during the process.
1/8" marine ply
hardwood framing & insulation (haven't decided upon thickness)
1/8" marine ply
decorative exterior strips (5/16" thick)
6oz fiberglass/epoxy
I believe that this would work, but if someone has suggestions/experiences, I would also love to hear them.
