Tongue box is now mounted properly. I installed 1" blue foam on the floor of the storage lockers and the tongue box. I went looking for a tongue jack after I weighed the tongue weight at the ball
(# 160
and yes that was level ).
As these 2 trailers are being towed tandum I knew I would need to be able to seperate them and hand push the chuck wagon where needed. Nope I can barely back up a single trailer but definatly ain't good enough to back up doubles !
I had been trying to justify the not quite $50.00 for a wheeled tongue jack but just couldn't do it. A couple night ago as I was driving home I stopped at a yard sale and found an ancient bolt on ball mount for $2.00 and 2 heavy duty 4" casters for a buck apiece. I bought about $5.50 worth of hardware and mounted the ball mount upside down on the tongue and secured it with a large "U" bolt thru the safety chain holes. The 2 mounting ears that normally bolted to the underside of the bumper are now upside down and accepted the 2 casters. Well to make a long story short I disconnected the chuckwagon last night and shoved it 30 feet thru the lawn and back into the driveway behind the barn and hooked it up to the barn for the first time. It rolled real easy and went where I pointed it so I was a happy soul.
A few days ago I found a semi mud flap in the road so I took it as a sign
and picked it up. Last night I cut it up and made mud flaps for the rear of the fenders. I had been towing it to and from work for 4 days in the rain and the sides were sprayed with a healthy layer of road grime so this addition should help a bit.
2 gas fittings to tape and reinstall and I am ready to pack up and head to the CRA
