weight-saving techniques
Postby eamarquardt » Wed Jul 28, 2010 11:36 am
A friend of mine has built several commercial fishing boats out of Airex foam and glass/polyester. One of his boats has been around over 30 years and is going strong. Although a little wood is used here and there (for engine stringers for example which take a lot of vibration from the diesel engines) there is little to no wood used in the construction of the decks and superstructures (he doesn't build the hulls and they are solid glass/polyester).
He does put more mat, roving, and glass on the decks than youse guys are talking about but his boats are holding up under some pretty rough service and doing well. There is no doubt in that a lightweight and durable tear can be constructed out of foam/glass. Maybe just a bit more material in the outside skin than is currently being discussed.
His web site is www.sbmar.com. No pics of the foam construction underway though. His boats look "factory" when he's done but they are all "hand made" foam glass construction with no molds being used.
Cheers,
Gus
eamarquardt
Images: 150
Postby glassice » Wed Jul 28, 2010 12:46 pm
I want it to work for you and doing prototypes they all want it as cheep as they can get I under stand that . when I start at 12 I sweep up just to get there scraps turn the drums on there sides to get the last of the resin tell I could do my first t bucket mold and 1 for the off road bug and hire a sell man no one want to do business with a kid and never look back the last 10 years over 60% has been doing prototypes aircraft work
We have done work for the courts and you think work with a engineer is a pain get 4 are 5 lawyers try to have it there way
When you add layers after it curs it not as strong. It 2 to 3 times more resin to add the ext-er layers and you will fight air
your post are quite impressive and there some that will take it as fact and can louse money fast
look at the guy on e-bay saying his bath tub walls will last
You did a great thing show the web site that show NO they wont't.
now this will cost me a job they want a real fiberglass tear to look like the home dep one for shows I told them no Maybe I will go to court when they get sued
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby oicu812 » Wed Jul 28, 2010 1:15 pm
24 ga. SS [Stainless Steel] = .025 +/- .001 1.03 lbs. sq. ft.
26 ga. SS[Stainless Steel]= .0188 +/- .001 .7725 lbs. sq. ft.
The 24 ga is easier to work with, 26 kinks if you look at it wrong.
Pie are square?
oicu812
Postby afreegreek » Wed Jul 28, 2010 2:35 pm
kennyrayandersen wrote:
oicu812 wrote:Thanks Kenny ray,that's the infomation I needed for comparison. I was thinking about 2" blue styro sandwiched between 24 ga. stainless
[1.03 lbs sq. ft.]. 6' tall/13' long with tear profile, about 60sq. ft. 125 lbs. for one finished wall. That sounds comparable to plywood, maybe a little less than ply.
You would surely fail the core LONG before you failed the skins. Generally the skins and core are sized to fail not so far from each other. I have no memory -- remind me how thick the 24 gage sheet steel is? You may be able to use thinner material than that. Typically .02 inches is a pretty robust facesheet for an aluminum honeycomb panel -- steel has thee time the stiffness of aluminum...
24 gauge non-galvanized sheet steel is 0.0239 and 24 gauge sheet aluminum is 0.0201
afreegreek
Postby afreegreek » Wed Jul 28, 2010 2:48 pm
eamarquardt wrote:A friend of mine has built several commercial fishing boats out of Airex foam and glass/polyester. One of his boats has been around over 30 years and is going strong. Although a little wood is used here and there (for engine stringers for example which take a lot of vibration from the diesel engines) there is little to no wood used in the construction of the decks and superstructures (he doesn't build the hulls and they are solid glass/polyester).
Cheers,
Gus
ya, the boat deck I mentioned is for a 40 foot luxury pleasure craft and consideration was given to weight more than durability.. it should last but care must be exercised..
I worked for a company that makes 90- 120 foot yachts and they are also pure glass/foam construction with the exception of the engine room where a large frame of aluminum I beams is installed to mount the motors, gensets and tanks to.. this is a complete unit type structure and only has 6 points of contact with the hull.. two over the keel and two at each chine.
afreegreek
Postby aggie79 » Wed Jul 28, 2010 3:27 pm
Dibond might be another material to look at. The 3mm thickness is about 0.75 pounds per square foot. It may be rigid enough to use with just a perimeter aluminum frame.
Postby afreegreek » Wed Jul 28, 2010 4:08 pm
here's something that has a lot of good qualities.. Nida-core
it's a plastic honeycomb core with thin ply on each side.. at the shop I'm at, we use it for floors over an aluminum stringers.. 3/4 spans 24 inches and feels solid underfoot. it's not that pricey either.. and comes in several thicknesses.
I'm planning to use it to make my next trailer.. a 16-18 ft TT
http://www.nida-core.com/spanish/nidapr ... eneers.htm
http://www.nida-core.com/pdfs/pds/nidac ... _Lauan.pdf
afreegreek
Postby glassice » Wed Jul 28, 2010 6:14 pm
afreegreek how are you going to finish the out side Lauan ?
glassice
Postby glassice » Wed Jul 28, 2010 6:50 pm
ken that we found for a lightest trailer with a 20 year life span is 15 mm gel-coat 1 layer.010" Thick veil 1 layer of1.5 mat 1 layer of Style 7781 E-Glass Satin Weave 9 oz 1 layer of 3/4 mat 1" of foam 1 layer Weave 9 oz 1 layer of 3/4 mat through most of the field
Is's the airy around the doors that need more from people pull them shelf in and out' the back of the fenders rocks bush THEN this surprise me it the in side wall space where there buts hit when turning over then where the hatch tie in we build are for a 75 year it cost about $250 more in the mold
glassice
Postby afreegreek » Wed Jul 28, 2010 7:37 pm
glassice wrote:afreegreek how are you going to finish the out side Lauan ?
I'm either going to use a combination of polished and painted aluminum or wood veneer and polished aluminum.. either way it will only be decorative panels attached to aluminum "H" the Nidacore will essentially be an interior wall with 1 inch foam between the sheet and the skin.. the metal 'H' will be PL'd to the Nidacore, foam will be slipped in the groves of the 'H' and the skin will be either PL'd (veneer panels) and or 3M tape for the metal.
because the 'H' is attached to the Nidacore with PL there is no wood to metal contact and because the foam sits in the 'C' section of the 'H' it doesn't touch the wood either. I will leave a little space at the top and bottom of the foam so air can travel between the foam and other surfaces..
afreegreek
Postby kennyrayandersen » Wed Jul 28, 2010 9:18 pm
afreegreek wrote:here's something that has a lot of good qualities.. Nida-core
Nidacore looks to me to have a few issues:
The plastic core appears to be kind of flexible (thus they are suggesting an alternate test for the strength). It’s too darn bad NOMEX core is so expensive! (It’s really that good). Notice, all Nidacore is, is Luan and plastic honeycomb. I’d like to see some properties on the plastic core they are using in the Nida core, but I suspect that it is polypropylene (which is kind of flexible).
Also the cost for a 1â€
kennyrayandersen
Images: 38
Postby kennyrayandersen » Wed Jul 28, 2010 9:57 pm
aggie79 wrote:Dibond might be another material to look at. The 3mm thickness is about 0.75 pounds per square foot. It may be rigid enough to use with just a perimeter aluminum frame.
I may be a bit confused, but after afreegreek’s post I’m a little clearer about what he’s trying to do. The problem with any of these very thin materials are that it just doesn’t take much load to make them go to poop. 3 mm is quite thin (Dibond), unless there is something to back it up. What I was trying to do is come up with a one-shot structural panel that would react the loads and be the finished product (another advantage to the fiberglass exterior). If the outside is Luan, then you still either need to glass it and paint, or use aluminum. That Dibond stuff is pretty expensive too (ouch!).
For the Nidacore to be used as just an inner, non-structural skin doesn’t make much [light-weight] sense; plus, it’s pretty expensive. Actually what would be hot is to make an aluminum sandwich, but I think with the coefficient of expansion so high for aluminum that you’d have to have a honeycomb core (it’s very free to expand in the plane of the facesheets) which would likely be cost prohibitive. Alternately, you could make a structural panel that does everything except the outside ‘finish’ (which could be aluminum sheet, which isn’t so expensive). You’ve already got the foam, and the inner could be made from the stuff they use on the interiors (kind of a plastic – non structural, but it’s pretty cheap, or you could just paint the luan, for that matter. On the exterior, if you could find a truck trailer repair place you could eliminate the seam which would be easier to seal.
What is going to take the shear load from trailer bending? It seems that the walls should be reacting that load, but I’m not sure how they are. What does the cross-section through the trailer at the axle look like? It seems you are making a metal frame, no? And how about the attachment of the panels to that metal frame? I think unless your frame is very robust, the walls still want to carry the shear load so they need to be tied to the frame somehow – how are you planning to do that?
Obviously, the lightest way to build is with some kind of monocoque, where the box (it’s so big, why not use it as structure!) is reacting most (if not all) of the loads. An airplane carries all of the loads on the outside surfaces because that’s the most efficient thing to do. If we can make the box (be it square or with the traditional curve) do the work, it’s the lightest way to go.
kennyrayandersen
Images: 38
Postby afreegreek » Wed Jul 28, 2010 11:11 pm
afreegreek
Postby Basinranger » Thu Jul 29, 2010 4:33 pm
I've been following this site & the discussion of using cheap insulation foam like you'd get @ home depot as a structural core.(I assume we are talking about blue dow foam insulation board - although there are MANY dow foams that are blue... only three are listed as structural foam - panel core 20 30 & 40 - and you don't find it at home depot...)
My first response is are you kidding? I'm looking forwards to seeing the results of using cheap foam structurally because if it works it would be great! It's a big leap from using thick ply skins with extensive solid wood infills and cheap insulation board glued in to an actual "composite sandwich structural panel" - meaning a panel where the skins take the load, giving you the weight savings & stiffness which make the trouble & expense worth it.
Never having made anything out of it I can't say it wouldn't work - but I have made many panels & structures out of structural cores - mainly balsa with both ply & glass skins bonded with epoxy.
Here's the argument for why it's a terrible idea - Without getting into too much detail the core material needs to have two main properties beside holding the two skins apart. It has to have sufficient compressive strength to keep the "top" skin from buckling - so it transfers the load efficiently to the other skin. Also it has to have enough shear strength to keep the skins from de-bonding & sliding off the core. It's also useful to have enough compressive strength to resist spot loadings from impacts.
Dow doesn't list the structural properties of it's cheap insulation foam - because it's not structural...
But here's how it's structural foam compares to the structural core materials I'm familiar with. Their properties get stronger as the density goes up in weight.
Dow Panel Core 20 - 20psi in compression 25 psi in sheer
Dow Panel Core 30 - 30psi in compression 35 psi in sheer
Baltek BalsaCore
917psi to 3813psi in compression
262psi to 712psi in sheer
Nida-core's H8PP 10 to 25 - the material in it's pre-made panels
188psi to 348 psi in compression
72psi to 87psi in sheer
Core Cell
80psi to 336 psi in compression
98psi to 287 psi in sheer
It's a good idea to know the basic properties of the materials you are using - often that explains their attractive price... I consider using 13.00 a sheet foam structurally to be a big risk - if anybody has experience with it or better yet Dows Panel Core product I'd love to hear about it, building lighter is better! Peter
Basinranger
Postby kennyrayandersen » Thu Jul 29, 2010 7:38 pm
Basinranger wrote:I've been following this site & the discussion of using cheap insulation foam like you'd get @ home depot as a structural core.(I assume we are talking about blue dow foam insulation board - although there are MANY dow foams that are blue... only three are listed as structural foam - panel core 20 30 & 40 - and you don't find it at home depot...)
Baltek BalsaCore - 917psi to 3813psi in compression, 262psi to 712psi in sheer
Nida-core's H8PP 10 to 25 - 188psi to 348 psi in compression, 72psi to 87psi in sheer
Core Cell - 80psi to 336 psi in compression, 98psi to 287 psi in sheer
You tell ‘em Glassice! (BTW, Glassice ain’t afraid to give you his opinion!)
Well, there’s structural foam and then there’s ‘structural’ foam HEhe
Dow doesn’t want to accept liability for the lighter-weight mass-produced foam, but the properties aren’t much different than the lower density foam that you listed (If I’m not mistaken, the densities are the same). If you scrounge around the internet, you’ll find that there are a lot of people using it to build all kinds of stuff.
My buddy is building and airplane out of it right now (from scratch, and not his first aircraft build!). He’s used it for the ribs, parts of the empennage, and parts of the fuselage. Interestingly enough, it wasn’t lighter to use it for the whole fuselage (he could have) as a wood (fir) stick frame (truss) turned out to be lighter. The whole plane including 3-axis control system and engine will be under the 254 pounds required to be categorized as an ultra light aircraft. He has already completed a successful static test of the wing (that’s pretty much the biggest and most important test as it’s generally considered bad form to lose the wings while flying!).
The process for the ‘structural’ foam might be a little more tightly controlled so that Dow can ‘guarantee’ the mechanical properties (or probably not), but pretty much the strength is dictated by the core density. If the core is denser, it can carry more loads (both tension and compression). Generally, and especially in the case of the Home Depot foam (also available at other bog box stores like Lowes) I’m guessing that it’s pretty much identical – it’s just mass produced. My airplane buddy is using reduced allowables (I think he is using 15 psi for the shear allowable), but when another airplane buddy of his did some testing, the strength was actually nearly 3 times that (around 70 psi if I remember correctly).
The problem with actual structural foams is that they are VERY expensive [as you may have noticed]; so, the key is getting a non-structural foam to do the task if possible (it isn’t always possible). For local load introduction we can use a puck (round insert which is generally potted into a composite sandwich and is either a metallic part, or made from potting compound, but we can use plywood, and it will do the same thing – it’s just not as fancy (we’re not about fancy, we’re about cost-effective (OK cheap, but don’t tell anyone)). I’d point out that there is a difference between the extruded foam (blue, pink, and sometimes white) and the white ‘beaded’ foam. The later is crap (and even it can be used if done carefully, but I personally wouldn’t use it).
Also, Balsa is generally pretty heavy core (relatively speaking), so that’s why the strength numbers look so good. Nidacore, is polypropylene, which is reportedly tough as nails, but it’s a bit expensive and flexible for my liking. Structural foams other advantage is that they come in many graduated strengths so that you can tailor the strength requirements very closely by splicing different densities in the same panel, only using heavier core where it is required (using this type of material is all about weight-saving in the end).
I could discuss composite failure modes with you until your eyes rolled back into your sockets and you slipped into a coma from which you likely would not return, but I hate to do that to anybody. Suffice it to say that generally light-weight thin-skinned sandwiches fail in either core shear, or facesheet wrinkling. Core shear is core shear, so that one is easy to figure, but facesheet wrinkling is a function of not only facesheet thickness, but core stiffness (denser foam is stiffer). If you provide more stability (stiffness) to support the facesheet, the wrinkling allowable goes up; when you make the facesheet thicker, the wrinkling allowable goes up. So, you can basically use thicker skins, because we don’t want to use denser foam, since it is more expensive (it may not be perfectly optimized, but it’s a wee bit of a compromise to save a lot of additional cost). Also, you can reinforce the core with plywood locally if you need to (Like where the axles attach, for instance). Usually this reinforcement won’t have to be very large as the load, and thus stress, spreads out pretty quickly.
One of the biggest areas of concern (pointed out by Glassice) is that core can peel away from the foam (I think this isn’t necessarily how the failure starts, but it can easily be mistaken for this failure mode). Regardless of how the initial sheet-to-skin failure occurs, the delamination can spread. This isn’t unique to the Home Depot foam, but all foams. I read a recommendation by one foam manufacturer that said you should put some holes 2 mm dia. X 3 mm deep (5/64 X 7/64 in, or thereabouts) spaced from 50-100 mm (2-4 inches). It’s also probably a good idea to rough up the surface with 60-80 grit and of course remove any films or coating that might be on the sheet. I think it likely that the initial failure is a facesheet wrinkling, followed up by facesheet peel. The hole should help arrest that (time will tell).
One other source that I m checking out is there are apparently people working in the insulation business that can custom slice whatever thickness you want out of a big block (the standard block dimensions are 5’X5’X10’) of the stuff and can vary the density as well; so, theoretically, you could get a bit denser (stronger) foam if you need it and get uniform and specific thickness sheets as required. I’m still checking that one out – there are evidently a couple of those places near Ft. Worth (where my permanent home is located).
I will be doing some verification test of mechanical properties before my build begins. All of the tests are pretty standardized, so that part isn’t particularly hard to do.
BTW, I’m CERTAINLY not the first to do this – there have been several in the past. Check the Uber ultra thread – I made a finite element model of a tear body and put in all of the properties for the sandwich when I ran the model (I hear I wasn’t the first to do that either, but I did document it so others could take a look at it).
The only problem with pre-made sandwiches is that you can’t do a curved surface, which limits the profile a bit.
kennyrayandersen
Images: 38
