d30gaijin wrote:Might you know if the EU2000i would run a 13.5k BTU RV air conditioner or should I go with the EU3000i? I'm thinking the latter (erring on the side of caution). If I could get by with the less expensive EU2000i that would be nice since there is a slightly used one available locally.
Thanks,
Don
I would agree with 8ball_99 and say no. I bought mine locally because they had a deal during a home and patio show. The 2000I is only 47 lbs and works very well but won't run everything.
HERE is a good place to look for the specs on each Honda. I have seen the 3000 but they are so big and weigh in at 143 lbs.
The 3000 is listed as 2,800 w with a max of 3000 and the 2000I is listed at 1,600w with a max of 2,000. The Honda's do have the option to pair up using a parallel kit that will run two of the same gens together to increase the available wattage. I did some checking prior to getting mine and found that most who have purchased the 3,000 version wished they had purchased two 2,000I's because of their weight and with them hooked together they have more power than the 3,000. I don't intend to use mine with an air conditioner so one was fine for me but that option is always there if needed later. For the price I paid, I could get two 2,000's for less money than the 3,000w. A lot of equipment rental places sell the Honda's so you could go check them out. I wanted one because they are easy on electronics and are very, very quiet. My dad had an old Craftsman gen that I was going to use a few years back and it was so loud I decided not to use it. I have been extremely happy with mine but don't use it all that much. Good luck on your quest and please let us know what you decide on and how it works for ya! The information could be helpful to others in the future including me.
8ball_99 wrote:I bought a Coleman Cub for my trailer exactly for this reason. Its a 9K BTU unit. Cost more but its smaller and uses less power. At 900-1100 watts it will work pretty well with a EU2000. I have ran it several times on the generator and it handles it NP.
Nice to know, thanks!
