silver spaceship
Postby R. W. Alexander » Wed Aug 04, 2010 2:49 pm
Rlowell wrote::applause: :applause: You gotta love the toys!! Great job on this build.
We are looking forward to seeing the final product. 8) 8)
Rod
Rod and Sharon thank you for the comments. She is about done. Liftoff should be in less than 2 weeks.
8)
R. W. Alexander
Images: 77
Living hinge
Postby R. W. Alexander » Wed Aug 04, 2010 3:04 pm
I put the plastic hinges on yesterday. They work really good.
I was going to put up a wider aluminum rain drip edge, but I did not like how it looked against the trailer.
[img][img]http://www.tnttt.com/gallery/image.php?image_id=69244[/img]
So I took some leftover .032 aluminum. Cut a couple of 1 3/4" strips 36" long, and clamped it between 2 radius-ed pieces of 3/8" ply. And lightly hammered away to form a j channel. I then heated up the aluminum and bent it around a curved piece of ply to get the curve I needed above the door.
R. W. Alexander
Images: 77
Postby Rlowell » Wed Aug 04, 2010 7:50 pm
:applause: I like it!!! I hope that my build turns out as good.
Rod 8) :applause:
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby Miriam C. » Wed Aug 04, 2010 9:01 pm
:applause: :thumbsup: :thumbsup: You are right, the J-channel looks better. The whole thing is really nice!
Postby GuyllFyre » Thu Aug 05, 2010 5:56 pm
Build looks amazing!
Where did you source the plastic hinges?
Things I have for sale on craigslist:
http://albany.craigslist.org/search/?ar ... catAbb=sss
Things I have for sale on eBay:
http://www.ebay.com/sch/merchant/seansmith
GuyllFyre
Postby R. W. Alexander » Thu Aug 05, 2010 8:44 pm
GuyllFyre wrote:Build looks amazing!
I got a 50ft coil of plastic hinge from Monroe engineering
http://www.monroeengineering.com/hinges ... -hinge.htm
It is a snap to install. I put some 1/8" x 1" aluminum flat bar on top marked some holes and drilled and countersink 3/16" holes on 6" centers.
R. W. Alexander
Images: 77
I messed up.
Postby R. W. Alexander » Fri Aug 06, 2010 4:27 pm
I did a boo, boo, on my rear hatch handle. I put it to close to the bottom edge. Which resulted in a large angle offset. I had drilled the hole already, so I was committed to putting the handle in that area.
So I figured out how to fix my problem. I cut off part of the shaft to the handle and added a small flex shaft that I never use. And welded it to the handle shaft.
[img]
That took care of the problem. No gaps.
R. W. Alexander
Images: 77
Postby Cliffmeister2000 » Fri Aug 06, 2010 4:33 pm
Pure genius! :applause: :applause: :D
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby R. W. Alexander » Fri Aug 06, 2010 4:34 pm
Miriam C. wrote::applause: :thumbsup: :thumbsup: You are right, the J-channel looks better. The whole thing is really nice!
Thank you. I does look better than the one I was going to use. And a lot cheaper than the $1.95 a foot price for J-channel. If I can use what I have lying around the shop. So much the better.
R. W. Alexander
Images: 77
Postby R. W. Alexander » Fri Aug 06, 2010 4:38 pm
Cliffmeister2000 wrote:Pure genius! :applause: :applause: :D
I don't think so. But did you know that the difference between a journeyman and a apprentice is..... the journeyman can hide his mistakes better. :lol:
R. W. Alexander
Images: 77
Postby Cliffmeister2000 » Fri Aug 06, 2010 4:41 pm
A journeyman has an apprentice to blame his mistakes on! :lol:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Rlowell » Fri Aug 06, 2010 5:43 pm
:applause: No matter which one of you did it...ya done good!!
I would have NEVER thought of adding another piece! Way to go!!
Rod :applause: :applause:
Rlowell
Images: 42
Except for a few items the trailer is done
Postby R. W. Alexander » Tue Aug 10, 2010 10:44 pm
I got most of the finish work done today. The head liner is in. I got the L.E.D. trailer lights connected, and put in a acrylic mirror with a mountain scene engraving. At this point the trailer is about done.
[img]
Image [/img]
[img]
Image[/img]
[img]
Image[/img]
R. W. Alexander
Images: 77
Postby Rlowell » Tue Aug 10, 2010 11:05 pm
:applause: :applause: She looks great!! Where are you taking her on her maiden voyage!? I can only assume she is going to the Wasach range come Friday morning! Have a blast!! How long did you work on her?
Rod :lol: :applause:
Rlowell
Images: 42
Postby R. W. Alexander » Wed Aug 11, 2010 8:43 am
Rlowell wrote::applause: :applause: She looks great!! Where are you taking her on her maiden voyage!? I can only assume she is going to the Wasach range come Friday morning! Have a blast!! How long did you work on her?
The maiden voyage will be Yellowstone Park. I have wanted to go to canyon village by Yellowstone falls for quite some time. As for how long it took to build. I started on July 6th, with the first cuts into some plywood. for a total of 24 working days. I have also started working on some new windows for #2. It is a Lexan window that's a 1/4" thick that fits into a window gasket and will fit into a plywood cutout in the side wall of the trailer.
R. W. Alexander
Images: 77
