by eamarquardt » Thu Aug 05, 2010 6:04 am
Shadow Catcher wrote:I have contemplated this for a couple of reasons. 1 aerodynamics and 2 to protect the gray water tank from rocks etc. You are looking at about $300 for a 4X8' sheet of 3/16 .190. If you have a steel frame you have to be concerned about isolating the aluminum it from the frame (galvanic action).
I used 1/8" for the sides of my dump trailer. I got 6 4X12 sheets years ago at a scrapyard, before scrap metal skyrocketed in price. Even though I had no immediate use for them I picked em up and dragged em home. Even with some pretty rough service and stuff banging around inside the trailer, they are undamaged.
I have to think 3/16 plate is more akin to "armor plating" than "protection". I think 1/16 with some supports would be sufficient. If you hit something that requires 3/16 plating, you're gonna have a bigger problems than a damaged gray water tank. In addition, a more forgiving structure will absorb energy, just like a "crush zone" in a car, and soften a major impact. I just watched a TV show where a pick up was rolled (killing one) when it ran over a tire, in the middle of the road, which got wedged in place under the truck and caused the truck to flip. Had the tire hit something with some "give" things might have been different. Ageless's observation that the aluminum was bent up around the perimeter suggests doing so is a good thing. It's gonna take a heck of a brake to bent 3/16 eight feet long. Just my thoughts.
Cheers,
Gus
