Waterproofing the wheel well
Postby tcolar » Mon Aug 02, 2010 5:47 pm
I'm almost done with my floor (1/2 ply with insulation & Henry 204).
Now I'm a bit concern about the wheel wells (frame extending over the wheels).
Obviously the tires are gonna be drawing a ton of water in there when the road is wet ... so i'm not sure just the roofing cement will be enough.
What should I do ? epoxy ? line it with something else like coroplast ... or maybe truck bed stuff.
it's an hf trailer .. so possibly I could also integrate the fender that came with it somehow.
Ideas welcome :)
tcolar
Images: 15
Postby Ageless » Mon Aug 02, 2010 5:56 pm
Ageless
Postby tcolar » Mon Aug 02, 2010 6:01 pm
That's a great idea !
Would be waterproof for sure, gotta see if I can find one around the correct size ... or maybe cut a large plastic bucket / tub.
tcolar
Images: 15
Postby tcolar » Mon Aug 02, 2010 9:14 pm
Guess what I found at H depot.
Now imagine it split in half !
tcolar
Images: 15
Postby Jst83 » Tue Aug 03, 2010 4:55 am
Wow looks like it was made for it :thumbsup:
Jst83
Images: 215
Postby Ageless » Tue Aug 03, 2010 12:51 pm
I'd be leary of that type of plastic. Unless it's thick and UV stable; might not hold up very long. The plastic barrels are quite thick and made for exposure to the elements and rough handling. I carry supplies in plastic totes and notice they become brittle and crack after a year of exposure.
Ageless
Postby tcolar » Tue Aug 03, 2010 1:06 pm
This is actually quite thick (much more than storage type bins).
It's a cement/concrete mixing tub, I'm not 100% sure about UV stability, but those are usually used outside (building construction) so it should be fine.
Also the wheel well shouldn't be getting that much sun (upside down, behind the wheel)
tcolar
Images: 15
Postby Mightydog » Tue Aug 03, 2010 1:16 pm
Build with the idea that you might need to replace it down the road...
Mightydog
Postby Ageless » Tue Aug 03, 2010 1:17 pm
OK, being for mixing concrete; should be pretty durable. Looks like a nice fit too.
You might try experimenting with heating the rolled edge and making it flat so that it will take a seal (gasket) so it could be replaced.
Ageless
Postby Mightydog » Fri Aug 06, 2010 11:57 am
tcolar,
Do you have any picrues yet??
Mightydog
Postby tcolar » Fri Aug 06, 2010 12:02 pm
tcolar
Images: 15
Postby emiller » Fri Aug 06, 2010 1:41 pm
And seal the seams with Napa sealer
emiller
Images: 157
Postby wannabefree » Fri Aug 06, 2010 9:33 pm
Belt and suspenders: fiberglass/epoxy, covered with black goo. But I like the plastic tub idea, too.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby kennyrayandersen » Sat Aug 07, 2010 12:50 pm
there would be no reason you couldn't use a steel barrel either AND the come in a few sizes -- it's UV stable as well. :lol:
kennyrayandersen
Images: 38
