kennyrayandersen wrote:Larry C wrote:kennyrayandersen wrote:you could always use a scraf joint as well -- that way you could even splice 1/8 inch plywood and could easily do a sandwich structure, which would be much lighter...
Kenny,
I think just a butt joint with epoxy/ fiberglass is all thats needed. Scarfing is difficult to keep straight. I built a Pygmy kayak kit 15 years ago that uses butt joints with 4MM Okume plywood.
Also I remember some scientific testing that was done on scarfing vs butt joints in boat building. It was a controlled test of various thickness plywoods.
The result was plywood under 1/2" was stronger with properly done a butt joints ( glass both sides), than a scarf joint.
I know that can bring a lot of arguments as it did on the boat building forum. However, from my personal experience, using thin ply, I think the butt joint is the way to go.
Here's butt joints being used to make long panels for a S&G kayak:
Larry C.
Sure, if you are going to glass both sides!!Tear walls aren't going to see much bending though, and if you were to scarf them, then bond them to foam and then glass over the outside... I'm guessing that would do as well. I was thinking to do a good scarf joint you'd have to make a router jig, but it wouldn't be that hard. In composited we use a 20/1 scarf -- I'm guessing that would work in plywood as well. Do you remember what the scraf ratio was in the test you read about? I'm guessing it's perhaps less than 20/1.
A butt joint with fiberglass fabric on either side would no doubt be robust enough.
I don't know the scarf ratio that was used, but I bet it was what ever is typical in boat building. The problem I see with scarfing thin ply is to get the strength to hold the panels together, the scarf will be steep which will make sharp fragile edges.
What I mean about butt joints is just using tape or narrow strips of glass at the butt joint, not glassing both sides of the whole panel. When I did the butt joints, I was able to lift the panels without worrying about breaking the joint. I don't think I would feel that secure with just a scarf holding the thin panel.
Isn't what we are trying to accomplish just holding the lengthened panel together till its bonded to the foam core? I think this should follow the "KISS" concept. The time it would take me to set up a jig to router the scarf, I could have the panels butted with thickened epoxy and taped applied to both sides of the joint.
Both methods are fine for thin ply, I am just comfortable with a different method than you.
