steve smoot wrote:Shadow Catcher wrote:A good bit of what could be wrong depends on the mileage. Cam belts are good for about 100,000 miles the cam belt idlers and tensioners need to be looked at and or changed. I have also heard of water pump failures.
my Subaru has 86k miles, and it's not the timing belt. It will still turn over and crank, just very rough idle and will not move under it's own power...
Yeah, if it started again, it's not the timing belt.
Might be a faulty Kuneutson valve.
http://kalecoauto.com/index.php?main_pa ... ducts_id=9
CD
