GPW wrote:I know youze' guys love CPES and Epoxy , but the 75% Mineral Spirits , 25% polyurethane mix .. works extremely well at waterproofing , and is Much less expensive and easier to apply ... Just slobber on several coats on your parts , before assembly (especially all end grains /voids) , and give a squirt into your drilled screw holes (old spray bottle ) ... Well tested in our most humid/rainy climate ...
The thin mixture sinks very deep into the wood and provides lasting protection , unlike a surface coating which may become damaged (leak) due to vibrations , twisting , etc...
Once dried completely , it accepts most any finish without problems ...![]()
If anyone is in doubt with this method , they should make a test sample to prove it to themselves ... Not only works on TDs either ... I used this on my porch and house door trim to stop the wood deterioration ... Works !!! and is Cheap ... Works great on interior paneling and Masonite too ...
