asianflava wrote:I'm just taking a guess here but: Without the camber, loading would be more important because sway is easier to induce. Am I right in this assumption? You all know about assumptions.
SteveH wrote:I would think heavy duty stub axles would be the mutt's nuts for off road use because it improves the clearance under the trailer. The good ones are also ride height adjustable.
Sonetpro wrote:Steve (Off the topic) I just noticed your a Retired Telecommunications Engineer. Who from? That's what I do. If you don't mind me asking.
madjack wrote:...knowing only too well, all about assumptions, I assume your assumptions are correct...sir
