...the green or ground wire goes to the silver bus bar on the far left...
...the white or neutral wire goes to the silver bar to its immediate right...
...the black or hot wire goes on the far right of the breaker where the red wires are attached(the red wires power the LED indicator lights)...
...for your source...
...on the main breaker with the black wire jumping to the copper colored bus bar...the main black wire from your source should go to a screw on the left side of that MAIN BREAKER(second breaker)
...the white wire from your source should goto a screw on the left of the top main breaker
...the ground or green wire from your source should goto the silver bus bar on the far left
![Cool 8)](./images/smilies/econ_kewl.gif)
