Don't mind me , just thinking , trying to keep things simple and light...
GPW wrote:What about moving the shower /potty to the rear .. move the bed/layout up a bit to accommodate ??? gray water tank ??? I was thinking more the universal bucket, just for a little shower/dish water ..![]()
Don't mind me , just thinking , trying to keep things simple and light...![]()
azmotoman wrote:WOW! I could build a mansion in there! Good luck to you and your plans for a conversion.
GPW wrote:Quote: "won't be able to get in via the side door without walking on the bed.
Hmmm?... I see where that could be a problem![]()
Here's a drawing I still consider workable in a CT ... Just more ideas to toss around..![]()
GPW wrote:Don, Have fun in the Mountains !!!
GPW wrote:Don, sealing the wood around that inlet wouldn't be a bad idea ... you can already see the water sucking up into the ply at the bottom (pic)
Engineer Guy wrote:Don ~
If there's a bit of spare +12 VDC wire about, consider leaving yourself a pig tail or two JUST in case a +12 VDC Accessory or two might be added down the road. Put in a little extra wire at the rear of the Trailer and/or just above your front shelf. You could put some heat shrink tubing or electrical tape, etc., around the loose ends of these wire pigtails. Photo-document where they are hidden. Or, dress them out to a Cig Lighter Socket or a blank cover plate now if that suits ya.
In any case, you'll have some modest 'expansion' capability to plug in a Cellphone Charger by the bed or shelf, or a lil +12 VDC Fan, etc.. Me, I'm a big fan of listening to Shortwave Radio at night occasionally w/earphone. For others, maybe listening to iPod music or a downloaded Book is their thing, daytime or nighttime. I'm a fan of plugging in high power +12 VDC Spotlights for external use during lil crises.
For future growth, you won't have to run surface mount or under-chassis +12 VDC wire. It will be just under the final Paneling should you need it.
Before Lawyers ran the world and Homeowners were kept away from their House under construction, I ran my own multiple Coax feeds and insulated HW Pipes in the walls circa 1987. I also carefully put Insulation around the Tub to lower heat loss while soaking. A pal ran his own wire to install a Whole House Fan later. I videotaped our present Tract House going up. It was very handy to know exactly where wiring and a wall brace were come time to cut in a Swamp Cooler outlet vent.
If any of us could foresee the future perfectly, we'd all be betting at the Horse Track, right?
~ Dennis ~
